View Poll Results: A poll
original set
54.55%
replaced lift pump 1x
27.27%
replaced lift pump 2x
0
0%
replaced lift pump 3x
4.55%
replaced lift pump 4x
0
0%
replaced injection pump 1x
13.64%
replaced injection pump 2x
0
0%
replaced injection pump 3x
0
0%
replaced injection pump 4x
0
0%
Voters: 22. You may not vote on this poll
How many fuel pumps has your truck had?
Old Nov 8, 2006 | 04:04 PM
mbaz's Avatar
mbaz
Default How many fuel pumps has your truck had?
I'm curious to know about fuel pump failures. Let us know how many pumps you've gone thru, how many miles you had when you had to replace, and what aftermarket pumps you might be using now.
For my part the dealer replaced under warrenty at about 40k miles both my vp44 injection pump and the lift pump with their replacement kit (new vp44 and the lift pump replacement into the tank, or so that's what was described to me, is that right?). I'm using Drew's Brew hoping this will keep my vp44 happier in the future.
Old Nov 8, 2006 | 04:23 PM
kingdog's Avatar
kingdog
Default RE: How many fuel pumps has your truck had?
I replaced my VP44 because of fuel starvation in my 02, ( at least that is what we figure it was), the carter in tank was replaced shortley after ( 500 miles or so ) with the F.A.S.S . Before F.A.S.S my fuel presure was 8- 9 and after the presure never went below 20, ( it kind of just stayed in the area of 20) no matter how hard I puched it.
I also started to use the Lucas Brand Lube after the VP44 , man did the guy that bought my 02 CTD get a great truck or what?
Ralph
Old Nov 8, 2006 | 04:41 PM
CowboyBob's Avatar
CowboyBob
My original lift pump went out at around 140k miles. It was replaced with the Carter in-tank pump. I did not replace the VP44 and now have 160k miles on it. I plan on putting a FASS pump on the truck some time this winter.
Bob
Old Nov 8, 2006 | 04:51 PM
Mayfair's Avatar
Mayfair
ORIGINAL: kingdog
I'm actually seriously thinking about making this my next mod. Did you get the FASS with the filters, or did you just get the pump?
Where did you get it?
Man I wish I had known in advanvce about your getting rid of your 2002 !! That guy got one helluva truck !!
Old Nov 8, 2006 | 05:33 PM
ramtradxb's Avatar
ramtradxb
My '04's pump went out at 45K miles. Kept that truck another 20K - don't know what happened after that. Supposedly the '06's have a different pump, and are less prone to failure - time will tell...
Old Nov 8, 2006 | 05:55 PM
Brent13's Avatar
Brent13
What is the difference between the lift pump and fuel pump? I'm a two month old diesel owner and don't even know what a lift pump is....
Thanks,
Old Nov 8, 2006 | 06:06 PM
Mayfair's Avatar
Mayfair
Same thing Brent
I too was confused at first
Old Nov 8, 2006 | 07:16 PM
jengel's Avatar
jengel
I have 80,000 on my original lift pump. Within the month, I will be putting on a AFS Big Dog Fuel System the uses the Walbro pump. Find them at http://www.altfuelsolutions.com/serv...y=Fuel+Systems
Old Nov 8, 2006 | 07:25 PM
Mayfair's Avatar
Mayfair
ORIGINAL: jengel
Be sure to take step by step pics of the install for us !!
Old Nov 8, 2006 | 07:39 PM
jengel's Avatar
jengel
ORIGINAL: Mayfair
ORIGINAL: jengel
Okey Dokey Smokey
