Hard start ~
Old Nov 10, 2006 | 06:41 AM
deuceandahalf99's Avatar
deuceandahalf99
Default Hard start ~
My '99 R3500 began to get balky when starting a couple of months ago. Instead of the usual "turn the key and it starts" it has become progressively worse, now taking up to ten seconds before it lights. Has an EZComp installed. 150K miles. Comments please.
Old Nov 10, 2006 | 01:35 PM
steve05ram360's Avatar
steve05ram360
Default RE: Hard start ~
check your fuel pump... if it's died it can take out your lift pump pretty quick.
Old Nov 10, 2006 | 01:55 PM
Mayfair's Avatar
Mayfair
Steve, do you think it could have anything to do with that intake heater thingy?
Old Nov 11, 2006 | 12:07 AM
jakebrake's Avatar
jakebrake
If there is no smoke, check your lift pump should be about 10psi. If there is smoke, as mayfair suggested, check the grid heater.
Old Nov 11, 2006 | 02:51 AM
Mayfair's Avatar
Mayfair
[/quote]
REALLY ??
I was just taking a guess !!!
MAN you guy's are starting to have an impact over here huh ??
Old Nov 12, 2006 | 02:27 AM
jakebrake's Avatar
jakebrake
You must be eating glue again mayfair, because things are starting to stick in your head
Old Nov 12, 2006 | 02:37 AM
RyEnFF31's Avatar
RyEnFF31
Had the same problem on the 2006 Ram 2500 CTD, Took it to the dealer, they said there was a flash upgrade for the computer. It took 5 minutes and havent had a problem since. Also gained 3mpg.
