possible Injection pump module?
Old Nov 15, 2006 | 10:27 PM
Hammerdown's Avatar
Hammerdown
Default possible Injection pump module?
I have no communition between my ECM and fuel injection pump. I don't have a crankshaft sensor on my 2001 truck. What else could this be other than the injection pump module? I don't have a clue...any help would be greatly appreciated.
Old Nov 15, 2006 | 10:48 PM
Hammerdown's Avatar
Hammerdown
Default RE: possible Injection pump module?
ARGH!! I am beating my head against the wall with this...I bought a crankshaft sensor (which my truck doesn't even have), and pulled the damn fuel tank out (cause I thought it was the fuel pump). Now I replaced the lift pump and it's working, but my truck still won't run...I just don't understand what the problem is....any help at all would be MUCH APPRECIATED!!
Old Nov 16, 2006 | 12:06 AM
jakebrake's Avatar
jakebrake
Any fault codes?
Old Nov 16, 2006 | 01:43 AM
Hammerdown's Avatar
Hammerdown
P1689
Old Nov 16, 2006 | 05:30 AM
Mayfair's Avatar
Mayfair
DAMN somebody's gottabe able to figure this out for ya!!
Old Nov 16, 2006 | 10:36 AM
Drew's Avatar
Drew
P1689 = Oil Pressure Control Solenoid Circuit Malfunction
I believe the 98.5 and up trucks need to have some sort of signal from the oil pressure transducer in order to fire
check the sending unit and make sure it's connected or it could be bad.
