Well Here We Go Again...
Old Nov 21, 2006 | 04:05 AM
Dodge This's Avatar
Dodge This
Default Well Here We Go Again...
About a month ago I had a check engine light on. Took truck to the dealer, they said it was a batt. temp senor code, cleared code good to go. Last week Had check engine light, called scheduled appointment, light went out, called the dealer and they said if light went out the truck is okay. Well the light came back on today. Have an appointment in the AM. Hopefully they fix something. I will keep you all posted.
Old Nov 21, 2006 | 05:24 AM
ramtradxb's Avatar
ramtradxb
Default RE: Well Here We Go Again...
DodgeThis - I just had the same code, but dealer said it was due to program and to correct it they re-flashed the computer. Did yours do the same, or just reset code? If they didn't reflash it, tell them they need to! (if they re-flashed it already, then I'll be watching for your update...)
Old Nov 21, 2006 | 12:45 PM
gtxpooch's Avatar
gtxpooch
I had the same problem and when they reflashed the computer the problem hasn't been back.
Old Nov 21, 2006 | 12:53 PM
Dodge This's Avatar
Dodge This
Well the tech just came out and said it had two codes stored one for ambent temp and something else. He asked about my radar detector that was plugged in. Then went back to work on the truck. I can see this will be fun...
Old Nov 21, 2006 | 02:28 PM
Mayfair's Avatar
Mayfair
ORIGINAL: Dodge This
LMAO ..... I'm sorry, that was funny. Good luck to ya bro !!
Old Nov 21, 2006 | 03:23 PM
MrSlug's Avatar
MrSlug
At least he did try to tell your your muffler bearings were worn out!
Old Nov 21, 2006 | 03:40 PM
Dodge This's Avatar
Dodge This
Well they checked all the sensor and they worked fine. They reprogrammed the computer. Hopefully this will be a good fix. If not back I go. [sm=gears.gif]
