gasser asking a dumb question
Old Nov 22, 2006 | 11:09 PM
shott8283's Avatar
shott8283
Default gasser asking a dumb question
hey guys.. loser gasser here.. lol
i was wondering if your guys 2gen CTD's came with single or dual batteries and if they were 12 volt or 24 volt.. reason why im asking is that there is a 205 amp alt for a 2gen CTD 5.9L and I wanted to make sure of what your guys's stock setup is.. thanks!
Old Nov 22, 2006 | 11:35 PM
mbaz's Avatar
mbaz
Default RE: gasser asking a dumb question
mine is a 2002, came with 2 batteries; 12 volt
Old Nov 23, 2006 | 01:47 AM
DieselDemon's Avatar
DieselDemon
95' 2 batteries connected in parallel. Still 12 volt, but double the cold cranking amps. I think the duals are more for the heater grid draw plus enough to turn the starter at the same time. After an all mechainal diesel starts up, it no longer needs any electricity to run.
Old Nov 23, 2006 | 03:12 AM
jakebrake's Avatar
jakebrake
I believe they are dual 650CCA 12volt batteries wired in parallel. I don't think your stock wiring harness from the alt to the batts will handle that alternator. You'll have to run a larger wire.
Old Nov 23, 2006 | 02:54 PM
Mayfair's Avatar
Mayfair
Hey Shott !!
Perhaps it's time you switched over to the "Dark Side" [sm=vader1.gif][sm=vader.gif]and got yourself a diesel ??
Old Nov 23, 2006 | 02:57 PM
Mayfair's Avatar
Mayfair
BTW: For those who don't now, Shott's got a really good nut and bolt thread floating at the top of the 2nd gen forum. Pretty much describing every nut and bolt on our 2nd gen trucks.
Nice job Shott !!
DieselDemon
You can use a 205 alt but you MUST increase the size of the charge wire from the alt to the battery. A 205 amp alt will not put out a true 205 amps due to heat. I would increase the charge wire to at least a 4 gauge. 2 is even better. Run it from the back of the alt to the battery. All done.
Swwwwwweeeeeeeeeetttttt!
Old Nov 24, 2006 | 08:38 AM
shott8283's Avatar
shott8283
ill be running 0 ga if i jump up that big.. itll be charging dual red top's .. with a batery charging smart box of some sort.. havnt picked on out yet.. thanks guys!
oh and p.s. i would love nothing more then come over to the dark side-cloud of smoke- and as soon as my gasser is paid for.. ill be driving it over to the dark side.. doing bout a buck to get there!
