new to the forum
Old Nov 24, 2006 | 02:22 AM
jester2255's Avatar
jester2255
Default new to the forum
Hi people I'm new to the forum and thought that I'd say hi and happy thanksgiving
I purchased a 2001 2500 quad back in september to tow my toy (jeep wrangler) and use as a commuter to and from work.
I found this forum shortly after i purchased it because I had some questions and you have answered almost all of them in other threads.
the only one I have is about the vp44. I have found lots of dealers selling remanned units.
I know this is an opinion question but is there any I absolutely should avoid.
blue-chip diesel seems to have done their home work industrial diesel is close to home and others seem to just have OEM style.
when I replace my pump I want to only do it once and I am going to either F.A.S.S. it or get the BD lift pump.
I am also going to install a low pressure warning light to try and prevent any more problems with the injector pump
you guys seem to know a lot from what i've read and I think I can trust your opinions.
Old Nov 24, 2006 | 02:42 AM
Mayfair's Avatar
Mayfair
Default RE: new to the forum
Welcome aboard jester. Glad to see that you've decided tono longer be a "lurker" and are no a poster. Stick with us !!
I don't know about your VP44 question, but I HAVE decided to go with the FASS system. Just a matter of picking which model.Drew has aso pointed out a Walboro ump that you might want to consider as well.
[sm=welcomesign.gif]
Old Nov 24, 2006 | 03:50 AM
steve05ram360's Avatar
steve05ram360
I think the FASS & Walbro pumps are feeding the VP44... I dont know of a good option for a replacement. I do know that the vp failures are usually caused by the lift pump dying and putting in a FASS or Walbro is an excellent replacement for the stock pump.
Old Nov 24, 2006 | 03:54 AM
sharx ram's Avatar
sharx ram
Welcome to the forum [8D] If someone around here cant help you then nobody can! However be careful of this guy that goes by Mayfair [8D]
Old Nov 24, 2006 | 05:26 PM
gtxpooch's Avatar
gtxpooch
Welcome to the forum If someone around here cant help you then nobody can! However be careful of this guy that goes by Mayfair
Yea, What he said!!
Old Nov 24, 2006 | 07:04 PM
jester2255's Avatar
jester2255
thanks guys I was actually asking about the dealers of the pumps.
I'd like to know about any that should be avoided
I think my trucks pump is going out but it's still running strong
it will smoke on start up ( whiteish) I thought it was the fuel heater I tested it. it's ok.
It dose the dead peddle, thought it was the APPS no codes for the APPS but there was a code 216
I even checked pressure for and aft of the lift pump, it checked out ok
I'm thinking with every thing I have found to read about it, I have a failing vp44.
If you have any more input it would be greatly appreciated.
Old Nov 24, 2006 | 11:43 PM
jakebrake's Avatar
jakebrake
I would first change the fuel filter before doing any thing else (cheapest part that will need replaced in time anyway) As for vp44's I don't know anyone running anything but oem, how ever I have been looking over the high preformance one from industrial injection. I'd figure that when my lift pump goes, I will replace everything. A FASS lift pump and the preformance one from industrial injection.
