trouble code P0341
Old Nov 27, 2006 | 02:15 PM
antano's Avatar
antano
Default trouble code P0341
hey.....good morning, i am from costa rica, and having a strange problem with my truck.
i keep geting this P0341 trouble code, and i have changed the sensor 2 times, it seems it only turns the check engien light when i use the ac.
CAN ANY BODY HELP.....
my theory is that i have a bad ac. compressor, and when it goes on, it slows the movemnto of the belt and then giving me a bad reading on the computer.
can this be my problem.......
help any body
regds
rodrigo
Old Nov 28, 2006 | 01:06 AM
NickBeek's Avatar
NickBeek
Default RE: trouble code P0341
Como esta Rodrigo, I don't have an answer for you, but someone here will. Good luck and welcome.
Old May 29, 2009 | 05:15 PM
bhaner's Avatar
bhaner
I am having the same issue. No fix yet.
Seems to happen more often after I change the oil...
Old May 31, 2009 | 07:27 PM
CarGuyOhio's Avatar
CarGuyOhio
P0341 is not a O2 sensor, it is the Camshaft Position Sensor. It is located near the ECM and is a cheap part, realtivly speaking.
Old post you dug up there
