P 0341 TROUBLE CODE
Old Dec 5, 2006 | 05:17 PM
antano's Avatar
antano
Default P 0341 TROUBLE CODE
HEEEEEEELLLP....HI RODRIGO FROM COSTA RICA
I HAVE CHANGED BOTH SENSORS (POSITION CAM SENSORS), SO THEY ARE WORKING OK NOW. I ALSO CHAGED THE POWER STEERING PUPM, BECAUSE IT WAS NOT WORKING PROPERLY, THINKING THAT IT WAS SLOWING THE BIG BELT. I HAVE CHECKED THE AC, AND THEY SAY IT IS WORKING OK. I GET THE CODE ONLY WHEN I USE THE AC.
CAN SOMEONE HEEEEEEEEEELLLLPPPPPPPP.........PLS
REGADS
RODRIGO TOMAS
antano@hotmail.com
Old Dec 5, 2006 | 05:44 PM
Drew's Avatar
Drew
Default RE: P 0341 TROUBLE CODE
only when useing the A/C you say. . . .I'm wondering if you have a bare wire that has chaffed through and is grounding out.
check the wires comeing from the A/C compressor and see if any are touching bare metal, if they are look to see if any have been rubbed enough to cause a grounding issue.
another issue might be the wireing harness to the fan. check both those out and let us know what you find.
Old Dec 6, 2006 | 06:55 PM
pyrokid's Avatar
pyrokid
P0341
Camshaft Position Sensor Circuit Range/Performance
If that helps any......
Old Dec 6, 2006 | 07:02 PM
Drew's Avatar
Drew
Ive seen this code pop up in the past when the A/C is turned on. . .most of the time is was the power wire to the A/C compressor that was grounding out.
