couple questions
Depends on how it was treated also is it a 12v or 24v the 98's had both. I would say the engine is probably good for another 50,000 miles. If its an auto, it definitly is time to rebuild it unless it has already been done. And my 1ton has limited slip
300~500k miles depending on how they are used & maintained.
when you look @ it check to see if it's a 53 block or not and do some research on the subject before you look at it. the 53 blocks have a cracking issue and you should know all about it before you look.
