CP3 questions...
Old Dec 13, 2006 | 01:28 PM
steve05ram360's Avatar
steve05ram360
Default RE: CP3 questions...
all of those lines under there are low pressure arent they? the lift pump is only what 10~15 psi? so tapping into them should be easy...
Old Dec 13, 2006 | 02:43 PM
Drew's Avatar
Drew
if your pump is in the tank then yea, 10-15psi. if the pump is filter mounted then there will be a vacuum.
