2007 6.7 Cummins HP/Torque manual Tranny
Old Nov 29, 2006 | 07:15 PM
MoparMax's Avatar
MoparMax
Default 2007 6.7 Cummins HP/Torque manual Tranny
What are the HP/Torque figures for the new 6.7 WITH a manual transmission???
Old Nov 30, 2006 | 01:58 PM
htgriffith's Avatar
htgriffith
Default RE: 2007 6.7 Cummins HP/Torque manual Tranny
Specifications
ENGINE: 6.7-LITER HIGH OUTPUT CUMMINS TURBO DIESEL I-6
Availability ---- Opt. - 2500, 3500; available Jan. 1, 2007
Type and Description ---- Six-cylinder, inline, liquid-cooled,
turbocharged, intercooled
Displacement ---- 408 cu. in. (6690 cu. cm)
Bore x Stroke ---- 4.21 x 4.88 (107 x 124)
Valve System ---- OHV, 24 valves, solid lifters
Fuel Injection ---- Electronic high-pressure common rail
Construction ---- Cast-iron block and head
Compression Ratio ---- 17.3:1
Power (SAE net) ---- 350 bhp (261 kW) @ 3,000 rpm
Torque (SAE net) ---- 650 lb.-ft. (881 N*m) @ 1,500 rpm w/6-spd. automatic;
610 lb.-ft. (827 N*m) @1,400 rpm w/6-spd. manual
Maximum High-idle Engine Speed ---- 3,500 rpm
Fuel Requirement ---- Ultra Low Sulfur Diesel
Oil Capacity ---- 12 qt. (11.3L) with filter
Coolant Capacity ---- 29.5 qt. (28.0L)
Emission Controls ---- Exhaust after-treatment systems and internal engine
features
TRANSMISSION: 68RFE ORION-AUTOMATIC, SIX-SPEED
Availability ---- Opt. with 6.7L turbo diesel engine; available Jan. 1,
2007
Description ---- Three planetary gear sets, one overrunning clutch, full
electronic control, electronically controlled converter
clutch
Gear Ratios
1st ---- 3.231
2nd ---- 1.837
3rd ---- 1.410
4th ---- 1.0
5th ---- 0.816
6th ---- 0.625
Reverse ---- 4.444
Overall Top Gear Ratio ---- 2.33 with 3.73 axle ratio; 2.56 with 4.10 axle
ratio
Old Dec 1, 2006 | 07:17 PM
MoparMax's Avatar
MoparMax
Why the difference with the manual tranny??
Old Dec 1, 2006 | 08:35 PM
DBLR's Avatar
DBLR
I don't think the clutch can handle any more than 610 Tq. I also heard they will be cut back to 325 HP for the manual trans for the same reason.
Old Dec 12, 2006 | 08:10 PM
MoparMax's Avatar
MoparMax
Why???? Are manual trannies not stronger????
Old Dec 12, 2006 | 08:19 PM
PRam's Avatar
PRam
no probably to keep from having to replace alot of clutches while still under warranty.
Old Dec 13, 2006 | 10:40 AM
Drew's Avatar
Drew
they can put in a clutch that can handle in excess of 550hp. my thinking is DC is wanting people to buy more automatics just the same way chevy detunes the d-maxie for sticks.
Old Dec 13, 2006 | 03:11 PM
Bucky's Avatar
Bucky
I think it's because the torque converter eats up the difference. It's my understanding that torque converters take away some of the power. I bet if you put identical trucks (with exception to the transmission) on a chassis dyno, the power numbers would be the about the same. THis is just my understanding of it, I am only about 95% sure that this is right.
Old Dec 13, 2006 | 03:22 PM
Drew's Avatar
Drew
you are right, but the difference power would more than make up for what is lost in the drive train.
