performance mods have started ... care to help ? ...
the stock CP3 and the stock injectors can handle 500hp no problem. you problems occur with the stock lift pump and the turbo. once you go above 100hp you need to change the both out. and if your wanting 500hp you would be better off just dropping the tank and yanking out the stock pump, installing a big line kit and the tank bypass so you can get 5 more gallons of fuel without the foaming
BTW, Jeff Garmon's shop is just down the road from where I work
ORIGINAL: Drew
I'm 3 hrs from Jeff but, it's the closets I can find to me for someone with good experience. Hope he won't mind a little ignorance on my part with these CTD's. :-)
he wont do you wrong
also if you have any more custom work that you want done theres another shop just up the road from him, Turbo's, he's good with lift kits, air bags, and fabs up a mean bumper
Jeff wont do you wrong
and if you have any more suspension work, or want some air bags check out Turbo's. he's just up the road from Jeff at the entrance of the industrial park you turn into. he also fabs up some mean bumpers, ladder bars and other stuff.
