PARKING BRAKE LIGHT ON...
I can't tell ya if the trucks are that sophisticated for that year. There's a manual you can download on this site. Last I knew your pads would have "squealer" on them to indicated the pads need to be changed. It's a bent piece of metal that makes a squealing noise against the the rotor when the pads have worn down. There would be one indicator per wheel.
Good luck.
Good luck.
thnks again, someone told me the problem was diferent pressure on the back lines, and since it was different it was triggering the light, any comments????
rgds
rodrigo tomas
san jose , costa rica
antano@hotmail.com
rgds
rodrigo tomas
antano@hotmail.com
Disconnect that single wire for the pressure differential switch and see if the light goes out. I am not that familiar with the newer trucks. I don't know if you have to restet the code.
Good luck with your ride.
i cant find that wire......is it on the abs module????
another question, if i bleed the back lines with a (vacum) machine......will that guarantee that i will have equal pressures on both lines? some book said my problem was uneven preasures on my rear lines
thanks
rodrigo tomas
thanks
rodrigo tomas
You can try bleeding, but I am pretty sure you said you had adequate brakes. Any chance you slammed the brakes on extremely hard, and the switch is stuck? I'm sure it's internal with all the rest of the valves. I will look at your 2001 manual that is available on this site.
Be back later.
Be back later.
hey....DIESELDEMON.....thnks alot for the help...its a 2003.....i really apreciate all the help, my mechanic wants to take the module below the abs system apart, see if the valve is there, i cant find the single wire that you mention, can it be different in my truck,???
i hate taking the truck to the dealer here....they are clueless.....
thanks
rodrigo tomas
san jose costa rica
antano@hotmail.com
thanks
rodrigo tomas
san jose costa rica
antano@hotmail.com
Dude, download the 2001 manual from this site. It has to be similar to yours. It is section 5 page 10&11 that describe the switch, and show where the wire is located. I cannot copy a page from my PDF and attach it here. I don't know why.
Let us know how you make out.
