winch mount
Old Jan 13, 2007 | 05:31 PM
  #21
gtxpooch's Avatar
gtxpooch
Default RE: winch mount
Sooooooo, you know how it goes..............If momma ain't happy, nobody's happy.
So true,so true!
Old Jan 18, 2007 | 02:30 AM
  #22
bert0168's Avatar
bert0168
Cumminalong, your winch mount looks awesome! If you haven't patend it yet Iam going to try to build it. I like how it puts the winch up higher than a lower frame mount.
My front hitch came today and I didn't even open it, its going straight back. Too bad I didn't see your post before I ordered it.
I had one question I came up with while scoping out my front end:
You are using 3/8" steel plate but the current tow hook brackets you are going to bolt toare only 1/8" (or less).
Either I have different brackets on my '05 2500 or strength isn't an issue in that structural plane?
Old Jan 18, 2007 | 09:48 AM
  #23
cumminalong's Avatar
cumminalong
That plate you are seeing is just a cover. There are bolts behind that that are actually one the other side of the frame that it's bolte too.
There is a little more beef there than jsut that little 1/8" plate.
Old Jan 18, 2007 | 10:30 AM
  #24
cumminalong
ORIGINAL: bert0168
Go for it brother! I'd be more than happy to use you as the test guinea for this!
Let me know if you run into a snag with it. I'd like to see it.
I took last week off from work to get some stuff done around the house and could have easily gotten this thing built, but the wife decided that she wanted a new hutch built for the living room. Here's what has been consuming my week:
Sooooooooooooooooooo.......as I stated before:
If momma ain't happy, nobody's happy!
Damn it! Has anybody seen my sack lying around anywhere?
Old Jan 18, 2007 | 08:46 PM
  #25
bert0168's Avatar
bert0168
I'm buying steel tomorrow. I am also going to do a wood mock-up of at least the tubing.
The hardest work is already done: The Idea.
I plan on taking pictures as we go and I'll post 'em when it's done.
Thanks again for the great idea.
Old Jan 18, 2007 | 08:52 PM
  #26
cumminalong
Doing the mock up with the wood will make it much easier to do the real one. Some 3/8" ply and a 2x2 (better get a 4x4 and cut it down to the actual receiver tube size 2 5/8 OD)
Yeah, I'll be interested to see it.
For the real one, are you gonna bend it or weld in the angles?
Old Jan 18, 2007 | 10:48 PM
  #27
squirtbottle09's Avatar
squirtbottle09
I know a guy that just purchased a warn winch with a air compressor built into it. he has the multi mount on it as well. I just cant justify putting a winch on a 50,000 dollar truck...
Old Jan 18, 2007 | 11:12 PM
  #28
cumminalong
ORIGINAL: squirtbottle09
Brother, a $50K truck is a perfect reason to have a winch. But, that's why I have a multi-mount setup, so I can take it off when I don't need it there.
I use mine all the time....
1 - not for wheeling, for pulling crap outta the woods that I would otherwise have to take my truck into; saving wear and tear on the truck
2 - pulling other guys out of their off-road adventures (see one of my previous posts)
Very useful tool.
Old Jan 18, 2007 | 11:15 PM
  #29
squirtbottle09
I just think that I shouldnt have my truck in a predicament to need a winch
Old Jan 18, 2007 | 11:23 PM
  #30
cumminalong
It's keeping it out of that predicament is what I use it for.
Example:
I like to cut my own wood. Both for burning and building things. I can go on post and cut all the wood I want. Now, you have a choice, drive your truck into where the good stuff is or cut it up into 8 - 12 foot sections, hook the winch to it and drag it over to where the truck is parked up at the firebreak and cut it into manageable chunks right there.
Saves a bunch of wear and tear on the back too.
Also, I'm always more than willing to help a friend, but I won't take my truck into a real nasty spot to pull some other 'tard out that couldn't see the signs (i.e. greenish-gray death mud). I'll never leave ya stranded and I'll help ya as much as I can, but I'm not destroying my truck to do it. Winch helps out in doing that.
Just my opinion, not everyone needs one, but it's damn handy.
