NV5600 Oil CHange
Old Dec 21, 2006 | 09:40 PM
CowboyBob's Avatar
CowboyBob
Default NV5600 Oil CHange
How do you drain the oil out of an NV5600 6 spped? I found the hex plug that is the filler/level check but can't figure out how to drain the oil. There are 2 acess plates, one on each side of the tranny, but there is a big warning sticker one each one about incorrect end play and shim will ruin the tranny. If I take one of these plates off will it drain the oil? and will I need to adjust something?
Thanks,
Bob
Old Dec 21, 2006 | 09:50 PM
dodgerules86's Avatar
dodgerules86
Default RE: NV5600 Oil CHange
Appears to be on the drivers side.
Holds appx. 4.5 liters.
[IMG]local://upfiles/948/E23E80FC29F64CDC8A93A8A3C5E8A2AB.gif[/IMG]
Old Dec 22, 2006 | 01:23 AM
CowboyBob's Avatar
CowboyBob
Thanks for the quick response!
Old Dec 22, 2006 | 12:19 PM
Drew's Avatar
Drew
you can use the bottom PTO bolt on either side to drain the oil.
I used the top PTO bolt to fill the trany with 5 quarts of amsoil 5-30
Old Dec 23, 2006 | 11:06 PM
Budlite's Avatar
Budlite
Drew, Are you saying use 5-30WT motor oil?
Old Dec 24, 2006 | 01:41 AM
CowboyBob's Avatar
CowboyBob
I put in the Amsoil synchromesh 5W-30. We'll see how that works.
