fuel mileage question
Old 12-29-2006 | 12:33 PM
Drew's Avatar
Drew
Default RE: fuel mileage question
go ahead and toss the seafoam in, dont worry about working the tank low.
the Rokk Tech crank sensor works well for many, however some do not have any changes. it is a bit hit or miss.
it is easy to install, less than 30 min. what it does is advance the timeing by 2 degrees. this makes the injectors fire a little earlier reduceing EGT's, but at the same time increaseing NOx emissions due to the lowered heat as the exhaust is comeing out.
some have noted anywhere from 1-2mpg gain from the sensor, and some have even stated their A/C works better. I can see this since the engine is more efficient with the added timeing you get a little more power down low.
Quick Reply: fuel mileage question
