Help!!! 04 diesel won't start, lift pump problem
Old Jan 12, 2007 | 01:58 PM
steve05ram360's Avatar
steve05ram360
Default RE: Help!!! 04 diesel won't start, lift pump problem
did you download the service manual form hemitruckclub.com? that should provide you the wiring, and fuse locations if any. You should have a relay & a fuse located in the fuse box... swap the relay with another as they are the same p/n and go from there. Also, you could have a bad ground going to the pump. when you measured the voltage was it across the connector or was 1 side to the frame?
Old Jan 12, 2007 | 04:25 PM
Mayfair's Avatar
Mayfair
DAMN .... you guy's sound like the CALVERY !!!
LOL !!!
