Stacks?...
Old Jan 12, 2007 | 02:07 PM
Mayfair's Avatar
Mayfair
Default RE: Stacks?...
ORIGINAL: DieselDemon
That is a sharp setup. I love stacks. Yours even look good at the bottom.
Cool beans.
[IMG]local://upfiles/12792/AD7D87A9AFAB4072848E3557B9FEA45E.jpg[/IMG]
Yeah, it DOES look cool !!! Unfortunately the pic of the crossover pipe was too small to really get the idea.
Whereabouts in PA are you Racer ??
Old Jan 12, 2007 | 03:35 PM
Drew's Avatar
Drew
the cross over tube is the black tube the stacks are mounted to. . .
Old Jan 12, 2007 | 03:45 PM
GOD RAM IT's Avatar
GOD RAM IT
yeah he only brings one pipe up to the bed and the black box is the splitter
Old Jan 12, 2007 | 05:11 PM
Mayfair's Avatar
Mayfair
Anyway, if you look under your truck Mayfair, you will see that from where the down pipe starts the bottom bend, it is only partially under the firewall. Then you have the length of a regular, extended, quad, or Mega cab, to do some work with the system before you get to the bed of the truck.
And before you ask, I have seen some guys that ......
1. Go straight back with a single pipe and cross over just in front of, or behind the transfer case/transmission center support. It's custom bending no doubt.
Man ..... I'm looking at my downpipe and I can't see where you'd tap into it AND be able to make the radical bend over the / inside of the trans tunnel. Seems like the trans would hit it.
[IMG]local://upfiles/42139/5FFCEDD5BE614B679D8ACB697382255C.jpg[/IMG]
Old Jan 12, 2007 | 05:47 PM
sharx ram's Avatar
sharx ram
Check this out Mayfair, it shows everything involved...http://www.blackclouddiesel.com/Stacks/stacks.htm#2stak
Old Jan 12, 2007 | 09:04 PM
Mayfair's Avatar
Mayfair
THIS shows the run throughthe bed option. What about doing it UNDER the bed ??
Old Jan 12, 2007 | 09:36 PM
sharx ram's Avatar
sharx ram
You cut it off right behind the muffler and use the flex pipe to connect it.
Old Jan 12, 2007 | 09:43 PM
Ben D.'s Avatar
Ben D.
I think your truck would look amazing with stacks on it. I mean it looks amazing to begin with but stacks would do even more for it
Old Jan 12, 2007 | 09:48 PM
sharx ram's Avatar
sharx ram
Thanks Ben, Iam going to put them on after seeing how they look [8D]
