looking for lots of rwhp
Old Jan 13, 2007 | 02:10 AM
bucknute's Avatar
bucknute
Default looking for lots of rwhp
first of, I do not know anybody that has built a truck to this level. to ask for some guidance.i've read several threads and see that u folks know the nuts an bolts on the CTD.as u can see im looking for some help here....OK .
for the fuel im looking at the FASSsystemi think this will do.EDGE juice w attitude stacked with the EZ. F1 injectors hp rating dint know? ATS exhaust manifold. and with the 4" strait pipe i now have,how much back pressure will i need to help spool the turbo up? the turbo is a problem, witch manufacture has the best. with little lag,an to witch size to get?for the clutch i have no idea in that department...
i think this will be a good start, your input will be great,an if u have other ideas feel free to chime in..
thanks to all
Old Jan 13, 2007 | 11:11 AM
cumminalong's Avatar
cumminalong
Default RE: looking for lots of rwhp
1 - You can't stack the Juice with and EZ. They use the same fueling setup and plug into the same connectors. If you wanna stack, you need a pressure box or programmer stacked with a timing / duration box or programmer
2 - What FASS system are you looking at? Your intended HP level is gonna determine which of the FASS systems you use.
3 - To spool the turbo, you want ZERO back pressure. Open exhaust is the fastest way to spool, but you do lose low end torque.
4 - The stock turbo is fine, up until you get over 40 lbs of boost. Then you are looking at trouble down the road.
5 - Tranny must be upgraded to handle power
Sounds like you need to do a few preliminary things first.....
1 - Decide what your expectations are
2 - Decide how much you intend to spend
3- Get gauges
4- Upgrade the trans
