when you have lots of HP........
Old Jan 22, 2007 | 10:04 PM
triton's Avatar
triton
Default when you have lots of HP........
not that my truck will be near as powerful as some of the built trucks here but, I haven't seen too much said about " motor mounts "
Do the factory mounts hold up to lots of torque ? Are they a weak point in the motor ?
I also haven't seen a lot about transfer cases. Do they require upgrading along with the typical upgrade for the tranny when producing high HP ?
Old Jan 22, 2007 | 11:01 PM
DieselDemon's Avatar
DieselDemon
Default RE: when you have lots of HP........
I am doing almost 420 to the rear and my mounts look SOLID. They are pretty hefty. Good question though. I'm curious myself.
Good luck with your ride.
Old Jan 22, 2007 | 11:05 PM
cumminalong's Avatar
cumminalong
The last part of the driveline that you'll ever need to worry about is that t-case.
That puppy is enormous.
I can't rememebr off hand, but these things are rated for some un-godly amount of lb/ft.
Let me peek around, I know I saw a rediculously high number for those.
steve05ram360's Avatar
steve05ram360
I havent heard of any need to upgrade the transfer case... not sure what you'd do to it either.
Old Jan 22, 2007 | 11:12 PM
cumminalong
Here ya go, I knew it was something ignorant
It'll handle 7,890 lb/ft of input torque and is good for vehicles with up to a 17,500 lb GVWR.
Uhhh, yeah....no breakage there.
http://www.dodgeram.org/tech/specs/tranfer_case.htm
Old Jan 22, 2007 | 11:20 PM
triton's Avatar
triton
ORIGINAL: cumminalong
Wow! that's a lotta handling ! It a shame the trans can't be built that way from the factory.
Nothing about motor mount though ? maybe even trans mounts. I know I down shift for to high a speed in my 1500 one time and snapped the mount like a twig.
Maybe the fact it's hard to find ( hold up info ) on the mounts means they're pretty stout too??
Old Jan 22, 2007 | 11:22 PM
cumminalong
Considering that I don't think anybody here has heard of anybody snapping a motor mount on one of these, I would say it's a safe bet that their fairly stout.
Old Jan 22, 2007 | 11:26 PM
cumminalong
ORIGINAL: steve05ram360
Really the only thing to upgrade in t-case is the actual gear set to get a lower range.
I replaced the gears in my Samurai t-case, down to a 4.3:1. Then I stipped the front output shaft, so that got replaced with a billet piece. All Four Cylinders Of Fury pushing 66 HP baby. Enought to scrare even the mightiest of hamsters and chipmunks.
