wait to start
Old Jan 25, 2007 | 11:55 PM
dodge2500diesel's Avatar
dodge2500diesel
Default wait to start
my wait to start light, trans tem, and water in fuel light dont come on when i turn my key on, i checked the fuses and realays, and cant find any blown ones, im stumped, and i dought that all 3 bulbs went out
Old Jan 26, 2007 | 12:03 AM
gtxpooch's Avatar
gtxpooch
Default RE: wait to start
What year of vehicle?? Has your vehicle been running? WTS won't come on above a certain temp, trans must be at a certain temp or higher to come on and water in fuel shouldn't unless there's water in the fuel.....someone will correct me if I'm wrong....
Old Jan 26, 2007 | 12:37 AM
dodge2500diesel
its a 96 i live in very cold weather, and all 3 of those lights are supposed to come on for at least a second, and they never do, and my dad, my girlfriend, and her brother all have the same truck and theres comes on every time
Old Jan 26, 2007 | 09:57 AM
Drew's Avatar
Drew
they are supposed to come on for a second as part of the initial dash test.
unless all the bulbs are blown, which is plausable, I would check the wireing harness and make sure it is still ok and not rubbing or giving you a hot ground.
Old Jan 26, 2007 | 05:10 PM
MrSlug's Avatar
MrSlug
If you want to check them, hold down the tripometer reset button while turning the igintion on (dont start the truck). This makes an 06+ RAM going into a gauge diagnostic check. If the lights dont light up duing the check, you have a problem. I would take it back to the dealer anyway since it is under warrenty.
BTW, my 06's water in fuel and trans temp warn does not come on either with normal starts (but they are working when I try the diag step above). I do get the wait to start (the curly little icon) when temps are below 40.
