RUN IT WITH OR WITH OUT THE PLATE?
Old Feb 9, 2007 | 02:21 AM
dodge2500diesel's Avatar
dodge2500diesel
Default RUN IT WITH OR WITH OUT THE PLATE?
i just bought a #8 fuel plate for my 96 when i pulled the fuel pump apart it didnt even have a stock plate i was just told thatyou get the most power with out any plate at all, is this true, what about fuel ecomomy, and exhaust temps, would it be better with or without the plate?
Old Feb 9, 2007 | 02:33 AM
jagj52's Avatar
jagj52
Default RE: RUN IT WITH OR WITH OUT THE PLATE?
Quick question... what is a "fuel plate"? What does it do? and What does it connect to?
Allen
Old Feb 9, 2007 | 02:42 AM
dodge2500diesel
its a little plate that goes in the fuel pump in the 12 valve engines, it determinds the fuel flow
Old Feb 9, 2007 | 02:54 AM
jagj52's Avatar
jagj52
Well, if it is on the 12V engines I guess i wont need to worry about it. My '01 was totalled on the 30th on my way back from Phoenix and after we get moved there on the 27th of this month I will start looking for a replacement. Have my eye on an '04, quad cab, 2500 w/ the HO engine. Has 45K on the meter but they are only asking $20K. Either that or an '04 out in Kansas.
Old Feb 16, 2007 | 12:32 AM
97raminator's Avatar
97raminator
Wow, no plate at all?!?!? Im not sure if that is a good thing or a bad thing. The way the plate works is the little hook lookin thing in the pump at diff rpm/boost levels engages the plate at diff heights to meter the fuel for that specific situaton. Yuo can move the plate backwards and forwards to tune your power curve as well as turn the fuel tune screw under the 8mm hex cap on top of the pump. You might call and talk to the guys at ats diesel or even BD diesel to see what they have to say. They are both very reputable and knowledgable companies that should be able to give you an accurate answer.
