Pictures of drain valve installed
Old Feb 12, 2007 | 09:42 PM
DieselDemon's Avatar
DieselDemon
Default RE: Pictures of drain valve installed
I'd be curious to see if the vibration from the engine was to ever work that valve open during driving. Seems like it could be snapped off while off roading, or in snow/ice conditions.
Good luck with your ride
Old Feb 12, 2007 | 11:11 PM
DBLR's Avatar
DBLR
ORIGINAL: Mayfair
Why's that ??
Gotta thng against nipples??
I had thought to say some thing along the line of, I do very much like Nipples but just not on a drain valve. But I was trying to be nice knowing that we do have a few women on this forum. Guess I can blame it on my parents and the way they raised me!
Old Feb 12, 2007 | 11:52 PM
handymanherb's Avatar
handymanherb
It is going to drain a little slower but you can do it hot because your hands are not going to be in the flow of the hot oil.
The nipple is just about a half of an inch below the axle and I sure you could find something to rip it out if you try hard enough, I can remove the nipple if needed , but I don't see the need I in Florida we don't have rocks, just sand and mud, so not much here to catch it on.
PS Dune I seen you pic's with the oil on your face, so I tilted my drain pan away from me, I guess I lucked out I didn't get any splash at all
Old Feb 13, 2007 | 12:19 AM
triton's Avatar
triton
ORIGINAL: DieselDemon
I don't think that's a problem. I just put one on myself the other day. The lever is spring loaded and very tight. It's not going to open by itself.
As for offroading.... you're gonna have bigger problems if you hit the valve because that means you've hit the oil pan. I think it's high enough under the truck to where that shouldn't be a problem.
Old Feb 13, 2007 | 03:34 AM
Mayfair's Avatar
Mayfair
It's a double action lever.You hafta push up, and while doing so push down in order to open it. I honestly see no way for it to open itself.
Old Feb 13, 2007 | 03:36 AM
Mayfair's Avatar
Mayfair
ORIGINAL: DBLR
Awww man don't make me out to be the bad guy. I thought I dd a pretty good job of showing / NOT showing the topic of discussion.
Old Feb 13, 2007 | 12:47 PM
DBLR's Avatar
DBLR
ORIGINAL: Mayfair
Mayfair you know none of us would do anything to make you look like the Bad Guy [sm=lildevil.gif] [sm=icon_sneaky.gif] [sm=smarty.gif]
Old Feb 13, 2007 | 02:07 PM
duneschick's Avatar
duneschick
Don't worry guys- I grew up with 2 older brothers [sm=boink3.gif]and no sisters. NOTHING offends me. Just makes me laugh!
And my boyfriend and his friends are mechanic/ construction workers (no offense guys).
Wouldn't recommend a hot OIL treatment to others. Picture did no justice (was caught off-guard)
Old Feb 13, 2007 | 06:36 PM
DBLR's Avatar
DBLR
Well you looked fine to me in that picture As for hot oil it all depends on what kind it is and whos putting it on me [sm=badbadbad.gif]
Old Feb 13, 2007 | 06:53 PM
duneschick's Avatar
duneschick
Make sure shes cute...... And Drives A DODGE!!!!
