ignition switch delay
Old Feb 14, 2007 | 05:36 PM
spanky spanky's Avatar
spanky spanky
Default ignition switch delay
I have a 2006 Dodge cummins and all the sudden when you turn the ignition switch to off and pull out the key there is a few seconds delay before the engine dies. Anyone heard of this happening before. It seems like a relay is sticking or something.
thanks
Old Feb 14, 2007 | 07:20 PM
steve05ram360's Avatar
steve05ram360
Default RE: ignition switch delay
welcome to DF... sounds like a problem, key off = no fuel, bring it back to the dealer for them to have a look.
Old Feb 15, 2007 | 01:10 AM
jakebrake's Avatar
jakebrake
I know some of the big bores run for a few seconds after key off. If I remeber right its the ecm powering down. Although that doesn't explain why it didn't do this before. You can try swapping relays out and see if that fixes it.
Old Feb 15, 2007 | 02:31 AM
spanky spanky
Ok I have figured it out. I installed a backup camera with a screen. I connected both of there positive wires to a pink wire from the switch that the service manual said wasthe accessory wire. I had to remove the camera to send it back for service. I think that is when it all started. That removed a load from I guess a capacitor that works with thescreen. When I turn the screen on and kill it, it dies.
