Front end question??????
Old Feb 19, 2007 | 06:23 PM
YAMAHARIDER5's Avatar
YAMAHARIDER5
Default Front end question??????
Ok i have a 2001 ram 3500 4x4 h.o 6 speed. And my question is wheni drive down the road the front end roars really bad like a harmonic like roar. And i dont know it could be other than the tires but thats not it! Could some one give me some ideas????
Old Feb 19, 2007 | 06:27 PM
cumminalong's Avatar
cumminalong
Default RE: Front end question??????
My "guess" would be wheel bearings.
Jack one of the tires of the ground, grab it on top and bottom and pull alternately. Then do the same from side to side. If you are getting play, in all directions than most likely the bearings are shot. If you are getting play up and down, then it's ball joints, but these won't howl.
Only other thing it would be, but I doubt, is the gear set.
Old Feb 19, 2007 | 06:38 PM
YAMAHARIDER5
So if it is wheel bearing could i do this myself or would a dealer or mech have to do it? Me and my dad are pretty good with tools.
Old Feb 19, 2007 | 07:03 PM
cumminalong
If you're semi-mechanically inclined, it's a driveway job.
The problem is that the bearings are not serviceable, you have to get the whole unit assembly, which can be pricey. From the dealer, I believe they are around $400 per side, but usually NAPA has them for around $230.
Here ya go, it's on the 2nd page. $204 w/o ABS, $254 w/ ABS
http://www.napaonline.com/masterpage...amp;SubCatId=3
Old Feb 19, 2007 | 07:36 PM
YAMAHARIDER5
Ok thanks guys!!!
