Walmart ramps ...
Old Feb 22, 2007 | 07:45 PM
Mayfair's Avatar
Mayfair
Default Walmart ramps ...
Do any of you guy's ahve those plastic ramps that you see at Walmart? One set is black and is rated to 8000 pounds, and the other is gray and is rated to 12000 pounds. Do any of you guy's use them? If so, which set?
I'm getting ready to change my oil this weekend ( and install my new lever ) and I was thinking about getting a set.
Old Feb 22, 2007 | 08:14 PM
Drew's Avatar
Drew
Default RE: Walmart ramps ...
I woud err on the safe side and snag the 12000 pounders. I have some 4 ton jack stands at home I use just for my dodge.
Old Feb 22, 2007 | 09:01 PM
Mayfair's Avatar
Mayfair
That's what i was thinking, but i wanted to see if anyone here had them and was happy with them first. They don't seem that tall ( 6" )
Old Feb 22, 2007 | 09:04 PM
Watermelon's Avatar
Watermelon
Get Danthetigerfan to fab u up some. Dont let WALLY have all the $$$$ !!
Old Feb 22, 2007 | 10:13 PM
dhvaughan's Avatar
dhvaughan
i needed a set of ramps for my son's honda accord. it only has about 4in of clearance, not even enough to slide in an oil catch pan, much less get your arm and shoulder under it. when i looked at the walmart ones, they were only about 5-6 inches tall. i wanted more height.
so i measured what angle his car would climb without catching on the ramp, which wasn't much, and decided to build ramps 4ft long, with a 1ft flat top and a 3ft angle section. i used 10ft long 2x10in, which is actually 1.5 x 9.5. out of each 10ft piece, i got 4 pieces. in order to have enough width, i used 5 pieces for each ramp, and used a total of (2 and 1/2) 10ft boards. cut them out with a skill saw. screw the first piece to the second with a bunch of drywall screws. screw the third to the second, the fourth to the third, and the fifth to the fourth. now the most important part... you don't want to drive off the end of the ramp, so build a stop on the end of the ramp. i used a couple of 2x4 pieces about 12-13 inches long, and screw them to the end of the ramps so they stick up and create a stop. just make sure that they are not too long, where they hit your front body parts.
you can make them as wide as you want by adding more 2x10's. just be sure they are wide enough to be stable. these things are incredible strong (and heavy), and will last lifetimes. they are plenty tall so i can get under them. since they are solid, nothing will ever overload them.
don't want to go to this much trouble but need more height. ok.. add 1 or 2 boards underneath the walmart ramps, slightly longer than the ramps and angle cut on the end. screw the ramps to the boards w/drywall screws.
Old Feb 23, 2007 | 01:51 AM
NickBeek's Avatar
NickBeek
I got the black ones. They work fine. Tried them on the minivan first. Drew, you'll be saying that soon. I have had my Ford truck on them, with no problems. I don't really need ramps for my truck, I can change oil with out them.
Old Feb 23, 2007 | 11:23 AM
Drew's Avatar
Drew
ORIGINAL: NickBeek
LA LA LA LA LA LA. . .I CANT HEAR YOU. . .LA LA LA LA
Old Feb 23, 2007 | 12:41 PM
DBLR's Avatar
DBLR
ORIGINAL: Drew
As the old saying goes, I’ve heard that one before†[sm=scared09.gif] [sm=sigh.gif] ROFLMAO
Old Feb 23, 2007 | 02:24 PM
Mayfair's Avatar
Mayfair
I got the gray ones last night and they worked just fine. I would have liked a little more height, but for now they worked just fine as is.
I thought about the black ones and they probably would have been fine, but the gray ones are a little wider so I went that route.
Here ya go Drew ...
Old Feb 23, 2007 | 02:44 PM
Drew's Avatar
Drew
I wish I could see the pic. . .dang government computers
