intake baffle
Old Feb 26, 2007 | 06:05 AM
Captain Squalus's Avatar
Captain Squalus
Default intake baffle
Can some one tell me the pro's and con's of debaffling the intake?
I am thinking of casting a new baffle tube out of aluminum. (less the baffles)
That way I will still have the original for warrenty visits to the dealer.
I am trying to figure out if it isworth the effort.
06 2500 QC long bed auto
Old Feb 26, 2007 | 07:32 AM
htgriffith's Avatar
htgriffith
Default RE: intake baffle
ALL it does is make the turbo spine noise loader. That is it.
Old Feb 26, 2007 | 10:00 PM
Nelspruitdodger's Avatar
Nelspruitdodger
What he said - I like it alot!
Old Feb 27, 2007 | 06:27 AM
Captain Squalus
Thank's for the info.
It moved several places down on the to do list but when I get a chance I'll make the pattern and core box and cast a couple of them out of aluminum.
Old Feb 27, 2007 | 11:24 AM
Drew's Avatar
Drew
dremel off both ridges on the ends and knock that bag boy out to realy hear your turbo sing
Old Feb 28, 2007 | 03:31 AM
Captain Squalus
ORIGINAL: Drew
Thank's Drew
But I want t keep the oringinal intak for warranty trips to the dealer.
If I was going to gut the original I would set it up in my mill or on the lathe to clean it out. (a little neater cuts)
When I some extra time that I need somthing to do with I will make a pattern and core box and cast a new one out of aluminum (less the baffles and maybe some internal fins to put a reverse rotation to the air flow to help the turbo grab more air IE: tamdem counter rotating props are more efficient than a single prop)
Old Feb 28, 2007 | 11:27 AM
Drew's Avatar
Drew
I like the idea, however for the size of the intake tube and the mass of air that is being drawn in, I doubt you would get the vortex of air your thinking about. I did a quick test on my restriction gage a while back and found that to pull the gage to the red you need about 1psi vacuum.
so granted you do have alot of volume, I dont think the pressure is realy there to support it.
Old Feb 28, 2007 | 11:00 PM
Captain Squalus
ORIGINAL: Drew
I haven't cruched the numbers yet on velocity and volume it was just an idea that came to the head in the middle of the night that I thought was worth doing the full engineering bit on. (haveing the 747 and a little more boost maybe)
(Got to keep in practice with the caculator and the autocad)
