Fuel filter
Old Mar 6, 2007 | 11:09 PM
brutusjr357's Avatar
brutusjr357
Member
Default Fuel filter
Someone told me to put some tranny fluid in the fuel filter canister at filter change to clean the injectors anyone heard of this or done it...
Old Mar 6, 2007 | 11:29 PM
cumminalong's Avatar
cumminalong
Default RE: Fuel filter
Uhhhhhhhh, no! Do not put tranny fluid in your fuel. If you want to clean the injectors, run 32oz of PS with about 1/4 tank of gas, find a nice big, long hill and git on it. That'll clear it right up.
Old Mar 7, 2007 | 12:04 AM
jasonreda's Avatar
jasonreda
Question What do you mean by PS.
Old Mar 7, 2007 | 07:56 AM
cumminalong
PS = Power Service Diesel Kleen. Use the grey bottle; the white is for winter andhas the anti-gel additive in it. The grey is meant as a Cetane booster and injector cleaner.
If you can find it, Stanadyne is great stuff, so is Howes. You can find that at Flying J, Pilot TA's, etc.
Old Mar 7, 2007 | 12:30 PM
Watermelon's Avatar
Watermelon
Rich, I would not do it to mine either, but my best friend uses it in his dumptruck to prime it at filter changes, Hes been doin it for years. Id never do it to a CTD but it hasnt hurt him. It would be just as easy to prime it with fuel. Our system primes itself at filter changes, Right?
Old Mar 7, 2007 | 01:04 PM
SMOKINGREY's Avatar
SMOKINGREY
don't do that some truckers do that the put a quart of tran fluid in 200 gallons of diesel.you can plug your filter doing that if you put in direct to your filter ,use the cleaner you can buy at walmart.or look at the drews brew.
Old Mar 7, 2007 | 02:18 PM
Mayfair's Avatar
Mayfair
ORIGINAL: Watermelon
I'm not sure ifI totally understand your question, but I fill the filter with diesel fuel before screwing it back on.
Old Mar 7, 2007 | 03:29 PM
DBLR's Avatar
DBLR
Mayfair,
I think he talking about the newer trucks that will self prime after the filter is changed. The newer trucks use a Cartridge type filter and not a Spin on type filter like you have, so their is no need to fill it after a filter change.
Old Mar 7, 2007 | 03:39 PM
cumminalong
ORIGINAL: DBLR
Mayfair,
Right, all you do is put the new filter in, key the ignition for a few seconds, turn off, key again, then start. It'll sputter just a bit as it forces the air out of the lines, but it'll light right off.
Old Mar 7, 2007 | 05:44 PM
Mayfair's Avatar
Mayfair
Well, my filter still sits in a housing, it's not exactly a "spin on" like an oil filter or something. I WISH it was that easy. When I get my FASS, it looks like those filters are true spin on like oil filters.
