oil pressure sensor/sender
Old Mar 11, 2007 | 05:01 AM
Dallas192's Avatar
Dallas192
Default oil pressure sensor/sender
well guys, my oilpressure gauge isnt working so I am going to replace the sender/sensor. Now the question is, where is the sensor located. I cant find it?....99 ram 2500 4x4 ctd auto quad cab........Dallas
Old Mar 11, 2007 | 02:22 PM
gtxpooch's Avatar
gtxpooch
Default RE: oil pressure sensor/sender
Steve posted this awhile back, it might help,
Have a look at the left side of the page... click on your year Ram ;-) beware, it's a large file
http://www.hemitruckclub.com/
Old Mar 11, 2007 | 04:58 PM
steve05ram360's Avatar
steve05ram360
that wont help him, he has a 2nd gen truck. go here https://dodgeforum.com/m_340929/tm.htm
an download the manual. it should give you everything you need to know as the motor you have was in production from '98 thru '02.
Old Mar 11, 2007 | 10:30 PM
Dallas192's Avatar
Dallas192
thanks guys, will download it tonite at work and take less time than home.......Dallas
Old Mar 12, 2007 | 09:00 PM
Drew's Avatar
Drew
I'm not sure about the 24valves, however if the sending unit is anything like the one in the HPCR engines all it detects is 5-10psi max. what you see on the instrument cluster is a computer generated figure of what the pressure MAY be. the computer looks at engine RPM and figures up a best guess on what the pressure should be. so even though you see 40psi, you may only have 15psi. and it could be the transducer is working, the computer may have a brain fart and is not computating the proper value, or the actual dash gage is not working.
Old Jul 7, 2018 | 12:40 PM
Retlaw43's Avatar
Retlaw43
Does any body know where Oil Pressure Switch is located on 2008 Grand Caravan 3.8l Engine ?
Old Jul 8, 2018 | 09:56 PM
Not a ram, not a diesel, try posting in the caravan section.
