jake brake hissing noise
Old Mar 15, 2007 | 12:19 PM
gtxpooch's Avatar
gtxpooch
Default jake brake hissing noise
This morning while warming up the truck, the jake brake was making a hissing noise like an air leak. Is this normal? I turned off the jake and it quit, started again when turned back on. I hadn't heard it before this morning.
Old Mar 15, 2007 | 12:43 PM
Drew's Avatar
Drew
Default RE: jake brake hissing noise
it is going to make a hiss normaly. . .however my truck when at a cold idle will hiss. . .not sure why,
you could check all the connections and make sure your air supply lines are ok.
ha ha ha. . .air supply
Old Mar 17, 2007 | 01:14 PM
CowboyBob's Avatar
CowboyBob
It is normal. Mine hisses at an idle all the time.
