valve adjustment
Old Mar 19, 2007 | 02:16 AM
416MX's Avatar
416MX
Default valve adjustment
Any one have the valve adjustment procedure for a 01 cummins, and the vp44 replacement procedure.
thanks in advance!!!
Old Mar 19, 2007 | 10:58 PM
jakebrake's Avatar
jakebrake
Default RE: valve adjustment
Valve adjust:
[blockquote]
Pull valve cover, breather tube, and breather filter element off (use a screwdriver or ratchet to stuff into hole and twist counterclockwise, be careful not to break filter housing). You'll need a flashlight and mirror to see the no 1tdc mark on the nut behind the breather element. Turn engine over to no 1tdc. adjust rockers 1,2,3,6,7,10. Turn engine 360. Adjust rockers 4,5,8,9,11,12. Rockers are numbered front to back. Valve lash specs are on engine data plate. Put it all back together and your good for another 100,000 miles.
[/blockquote]
If your changing the vp44 at the same time, That nut behind the breather holds the pump gear on. You'll want to pull the fan and shroud to get better access to it.
Old Mar 19, 2007 | 11:34 PM
416MX's Avatar
416MX
Thanks for your help.
Old Mar 19, 2007 | 11:43 PM
Drew's Avatar
Drew
.010 on the intake and .020 on the exhaust just in case you didnt have that part.
Old Mar 20, 2007 | 12:09 AM
416MX's Avatar
416MX
Thanks for the info, I've got to replace the vp44 on it too and i'm trying to figure out do i do it myself or have the guy i'm getting my pump from do it for $350. I'm pretty sure i can do it, but i know i'll get agravated.
