'05 Recall
Old Mar 22, 2007 | 10:46 AM
KenZ's Avatar
KenZ
Default '05 Recall
Got a question for you all. My dealer tells me I have to bring my truck in for recall work. Says they need to replace the coil spings. My truck is a '05 Quad cab 2-wheel drive dually diesel with 6-spd. Truck drives fine, and the service manager don't know why its being done, just that in needs to be done. I received nothing from Dodge telling me about a recall. I have searched the net and found nothing about it either. The only recall I can find has to deal with automatic trans trucks. I don't want to do this for no reason. Does anyone know of this recall, and why it needs to be done?
Thanks
KenZ
Old Mar 22, 2007 | 11:21 AM
Drew's Avatar
Drew
Default RE: '05 Recall
I dont see anything reguarding the suspension
http://dodgeram.info/tsb/index.html
Old Mar 22, 2007 | 02:16 PM
htgriffith's Avatar
htgriffith
This is all I could find on the supension and Trans.
Recalls Summary
Make / Models :
Model/Build Years:
DODGE / RAM 2500
2003-2007
DODGE / RAM 3500
2003-2007
SUPERLIFT SUSPENSION / 04-4640
9999
SUPERLIFT SUSPENSION / 4007
9999
SUPERLIFT SUSPENSION / 4640
9999
SUPERLIFT SUSPENSION / 4640B
9999
SUPERLIFT SUSPENSION / 4640R
9999
SUPERLIFT SUSPENSION / 4645
9999
SUPERLIFT SUSPENSION / 4645B
9999
SUPERLIFT SUSPENSION / 4650
9999
SUPERLIFT SUSPENSION / 4650B
9999
SUPERLIFT SUSPENSION / 4650R
9999
SUPERLIFT SUSPENSION / 4655
9999
SUPERLIFT SUSPENSION / 4655B
9999
SUPERLIFT SUSPENSION / 4655R
9999
SUPERLIFT SUSPENSION / 4660
9999
SUPERLIFT SUSPENSION / 4660B
9999
SUPERLIFT SUSPENSION / 4665
9999
SUPERLIFT SUSPENSION / 4665B
9999
SUPERLIFT SUSPENSION / 4670
9999
SUPERLIFT SUSPENSION / 4670B
9999
SUPERLIFT SUSPENSION / 4670R
9999
SUPERLIFT SUSPENSION / 4675
9999
SUPERLIFT SUSPENSION / 4675B
9999
SUPERLIFT SUSPENSION / 4675R
9999
SUPERLIFT SUSPENSION / K756
9999
SUPERLIFT SUSPENSION / K756B
9999
SUPERLIFT SUSPENSION / K756R
9999
SUPERLIFT SUSPENSION / K757
9999
SUPERLIFT SUSPENSION / K757B
9999
SUPERLIFT SUSPENSION / K757R
9999
SUPERLIFT SUSPENSION / K760
9999
SUPERLIFT SUSPENSION / K760B
9999
SUPERLIFT SUSPENSION / K760R
9999
SUPERLIFT SUSPENSION / K761
9999
SUPERLIFT SUSPENSION / K761B
9999
SUPERLIFT SUSPENSION / K761R
9999
SUPERLIFT SUSPENSION / K821
9999
SUPERLIFT SUSPENSION / K821B
9999
SUPERLIFT SUSPENSION / K821R
9999
SUPERLIFT SUSPENSION / K822
9999
SUPERLIFT SUSPENSION / K822B
9999
SUPERLIFT SUSPENSION / K822R
9999
SUPERLIFT SUSPENSION / K823
9999
SUPERLIFT SUSPENSION / K823B
9999
SUPERLIFT SUSPENSION / K823R
9999
SUPERLIFT SUSPENSION / K824
9999
SUPERLIFT SUSPENSION / K824B
9999
SUPERLIFT SUSPENSION / K824R
9999
SUPERLIFT SUSPENSION / K832
9999
SUPERLIFT SUSPENSION / K832B
9999
SUPERLIFT SUSPENSION / K832R
9999
SUPERLIFT SUSPENSION / K833
9999
SUPERLIFT SUSPENSION / K833B
9999
SUPERLIFT SUSPENSION / K833R
9999
SUPERLIFT SUSPENSION / K834
9999
SUPERLIFT SUSPENSION / K834B
9999
SUPERLIFT SUSPENSION / K834R
9999
SUPERLIFT SUSPENSION / K835
9999
SUPERLIFT SUSPENSION / K835B
9999
SUPERLIFT SUSPENSION / K835R
9999
Recall Number:
07E009000
Summary:
CERTAIN LKI ENTERPRISES, INC., BRAND NAME SUPERLIFT SUSPENSION, PITMAN ARMS SOLD AS REPLACEMENT EQUIPMENT FOR 2003-2007 DODGE RAM 2500 AND 3500 4X4 LIGHT TRUCKS. DUE TO INADEQUATE HEAT TREATMENT DURING PRODUCTION, THE AFFECTED PITMAN ARMS MAY DEVELOP CRACKS IN THE UPPER SPLINED ATTACHMENT ATTACHMENT TO THE STEERING OUTPUT SHAFT. MOVEMENT BETWEEN THE PITMAN ARM AND THE OUTPUT SHAFT MAY DEFORM SPLINES, RESULTING IN PREMATURE WEAR AND FATIGUE FAILURE OF THE AFFECTED PITMAN ARM.
Consequence:
PITMAN ARM WEAR OR FAILURE MAY LEAD TO LOSS OF VEHICLE CONTROL, POSSIBLY RESULTING IN A VEHICLE CRASH.
Remedy:
LKI WILL NOTIFY OWNERS AND REPLACE THE PITMAN ARM, IF NECESSARY. THE RECALL IS EXPECTED TO BEGIN DURING FEBRUARY 2007. OWNERS MAY CONTACT LKI AT 1-800-551-4955.
Notes:
LKI RECALL NO. 07-01PIT. THIS RECALL ONLY PERTAINS TO REPLACEMENT LKI, SUPERLIFT SUSPENSION KITS,AND HAS NO RELATION TO ANY ORIGINAL EQUIPMENT INSTALLED ON DODGE RAM 4X4 LIGHT TRUCKS MANUFACTURED BY DAIMLERCHRYSLER. CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
Transmision
Make / Models :
Model/Build Years:
DODGE / RAM 2500
2003-2005
DODGE / RAM 3500
2003-2005
Recall Number:
05V462000
Summary:
ON CERTAIN PICKUP TRUCKS EQUIPPED WITH DIESEL ENGINES AND AUTOMATIC TRANSMISSIONS, IN AN ATTEMPT TO EXIT THE VEHICLE QUICKLY WITHOUT SHUTTING OFF THE ENGINE AND REMOVING THE KEY, THE DRIVER MAY INADVERTENTLY LEAVE THE AUTOMATIC TRANSMISSION SHIFT CONTROL IN INDICATED REVERSE.
Consequence:
THIS ERROR IS AN UNINTENDED ACTION THAT MAY RESULT IN A LACK OF TRANSMISSION PARK PAWL ENGAGEMENT AND POSSIBLY DELAYED REARWARD MOVEMENT OF THE VEHICLE.
Remedy:
DEALERS WILL PERFORM A SOFTWARE MODIFICATION TO EQUIP THESE VEHICLES WITH AN OUT-OF-PARK ALARM. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER CAMPAIGN NO. E17. THIS ACTION IS DEEMED A SAFETY IMPROVEMENT CAMPAIGN AND IS NOT BEING CONDUCTED UNDER THE SAFETY ACT. THE COMPANY HAS INFORMED NHTSA THAT IT WILL PROVIDE THE MODIFICATIONS DESCRIBED ABOVE FREE OF CHARGE.
Old Mar 22, 2007 | 02:43 PM
htgriffith's Avatar
htgriffith
Service Bulletins
Make : DODGE
Model : RAM 2500
Year : 2005
Manufacturer : DAIMLERCHRYSLER CORPORATION
Service Bulletin Num : 2100606
Date of Bulletin: MAR 11, 2006
NHTSA Item Number: 10019633
Component: POWER TRAIN:MANUAL TRANSMISSION
Check to Request Research. Submit below.
Get Summary
Make : DODGE
Model : RAM 2500
Year : 2005
Service Bulletin Num : 2500106
Date of Bulletin: FEB 01, 2006
NHTSA Item Number: 10019529
Component: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL
Get Summary
Make : DODGE
Model : RAM 2500
Year : 2005
NHTSA Item Number: 10019536
Component: EQUIPMENT:OTHER:LABELS
Get Summary
Make : DODGE
Model : RAM 2500
Year : 2005
Service Bulletin Num : 2304605
Date of Bulletin: OCT 01, 2005
NHTSA Item Number: 10017637
Component: STRUCTURE:BODY
Get Summary
Make : DODGE
Model : RAM 2500
Year : 2005
Service Bulletin Num : 2101505
Date of Bulletin: SEP 01, 2005
NHTSA Item Number: 10017000
Get Summary
Make : DODGE
Model : RAM 2500
Year : 2005
Service Bulletin Num : 2101605
NHTSA Item Number: 10017001
Get Summary
Make : DODGE
Model : RAM 2500
Year : 2005
Service Bulletin Num : 05009
Date of Bulletin: JUN 03, 2005
NHTSA Item Number: 10016906
Get Summary
Old Mar 22, 2007 | 02:58 PM
Mayfair's Avatar
Mayfair
If you DO take it in, don't let em install the horn honking device.
Old Mar 22, 2007 | 07:37 PM
PRam's Avatar
PRam
yeah!
Do not let them re-flash your computer,
they did my truck without consent and it is annoying.
paul
Old Mar 22, 2007 | 11:06 PM
KenZ's Avatar
KenZ
Thanks guys. That's all I could come up with too was the auto trans, which don't pertain to me, and the steering link, which looks like a aftermarket part. It made me a little suspicious when the service manager wanted to do the work but couldn't answer any of my questions about what and why it was needed. As for reflashing the computer, I got way to many bells and noises now, I sure as heck don't need anymore! I think I will go to a couple more dealershps in the area and see if they give me the same line and see if they can show me something written down on paper. Will post any info I get. Until then, I think I will take the long way around the dealership!
Thanks, again
KenZ
michigan
Old Apr 5, 2007 | 01:17 AM
KenZ's Avatar
KenZ
Well, I went to another dealer today and inquired about a front spring recall for my '05 dually. They couldn't find anything thru there normal channels. They did find this particular recall, but had to use my VIN # to locate it. Seems there were 8500 or so trucks that possibly had the wrong coil springs installed. These wrong springs are weaker and could bottom out and cause loss of control. They said it was being done in 3 seperate groups and I am in the second group, which is the reason I didn't receive anything from Chrysler yet. The service manager said that there was no inspection ordered for the recalled parts, just replacement. Since this guy spent the time to dig and find the info for me, and let me read the recall notice on his computer, I decided that his dealership will get to do the replacing. Even though I am in the second recall group, the parts are available, so I should have the work done in a week or so. The only thing I didn't really agree with him was that he told me that a recall is based on safety acts and usually mandated by the government and you should have all recall work done no question asked. First off, its my truck not there's and noone is tearing it apart unless there is a good reason. Plus, whenever the government is involved, I ask alot of questions!
I will also mention that the computer has nothing to do with coil springs, so keep away!!
KenZ
michigan
