Performance/mileage enhancers
Old Mar 24, 2007 | 01:11 AM
1quik69's Avatar
1quik69
Default Performance/mileage enhancers
I have a 2001 quad cab long bed with auto trans. I am looking for some recommendations for changes to increase the gasmileage mainly. If it goes better so be it. I currently get around 15-17mpg in town. At $3 gal. I think it would be worthwhile to make some changes. Thanks.
Old Mar 24, 2007 | 04:24 AM
XFIRE's Avatar
XFIRE
Default RE: Performance/mileage enhancers
do a search, there are pleanty of threads on fuel mileage
Old Mar 24, 2007 | 12:03 PM
HankL's Avatar
HankL
from the begining of the MPG FAQ:
Those with Cummins engines may first want to read the 'White Paper'
from Cummins called:
"Secrets of Better Fuel Economy: The Physics of MPG"
which is oriented toward 18 wheel trucks but 90% applies to Ram pickups too.
http://www.cummins.com/na/pdf/en/pro..._Whitepape.pdf
Old Mar 24, 2007 | 03:44 PM
steve05ram360's Avatar
steve05ram360
ORIGINAL: 1quik69
are you kidding me??? well OK... use the Drews Brew and get an AFE drop in filter... then you could also get the tailgate extention that is on the 2005 & newer 1/2 ton trucks, it is said to be worth approx .5 mpg
Old Mar 25, 2007 | 12:03 PM
HankL's Avatar
HankL
For city driving
the three most effective ways to increase MPG are:
buy low rolling resistance tires
buy a block heater and warm the engine before you start it
drop the weight of the truck somehow
much more info in a very long read at:
https://dodgeforum.com/m_447500/tm.htm
Old Mar 25, 2007 | 05:26 PM
nomolos1's Avatar
nomolos1
I gained 4 mpg with these mods
1 Drop in filter
2 Edge Comp (keep on stage 5)
3 oil cooler
4 Electric fan
5 biult transmission (because tranny died on me) Big valve body, and 2000 ft tq converter
6 remover silencer ring (probably didn't do anything, but make the turbo louder)
7 4" exhaust (keeps temps down from more turbo boost)
Old Mar 25, 2007 | 07:42 PM
cumminalong's Avatar
cumminalong
ORIGINAL: nomolos1
1 Drop in filter
3 oil cooler
4 Electric fan
Your biggest improvement probably came from that tranny and TC, as well as that electric fan. Having a TC that locks up tight and a tranny that shifts well, does wonders for performance AND mileage. Freeing up that fan does wonders as well.
I don't know if I'd go to that extreme for the sake of mileage though. You'll spend a lot more money that you'd ever recoup in fuel mileage. It's like doing a gear swap for mileage.....it'll never pay for itself.
Old Mar 25, 2007 | 09:29 PM
cmnspwr's Avatar
cmnspwr
My Smarty gave me roughly a 2-2.5 mpg increase. The power is awesome too!
Old Mar 26, 2007 | 09:45 AM
nomolos1's Avatar
nomolos1
The tranny upgrades and fanhelped in the low end. The edge comphelpedwhile in cruise mode.
Old Mar 26, 2007 | 11:19 AM
cumminalong
ORIGINAL: nomolos1
That's were I'm seeing pretty good gains as well with mine. I spend a good majority of my time cruising at 50 - 60 mph on rolling hills. If I have the Juice on Lvl 3 or 4 while I'm cruising in this terrain, I notice my mileage goes up a bit, by about 1/2 MPG or more compared to the lower settings.
