winning noise
No, just got my srt last night. But if I hear that noise I'll reply back. However, I noticed this morning when i fired it up, it had an slight unusual noise that stopped after pressing down on the clutch. anybody else?
I also have this, can really hear it in the garage. Only does it when it is cold. About 1-2 seconds after it starts and lasts 5-10 seconds. I figure when I have my new exhaust on I will no longer hear it
Update
Found information that the noise comes from aftermarket oil filters. M1 filters will make it happen. If you run a Mopar filter it appears the noise, which almost sounds like a fan starting to spin up, will not occur. I will confirm this when I change my oil this winter.
Trending Topics
The noise you are hearing is comming from an aftermarket oil filter. I had the same problem. I switched to a factory filter and no more noise. I also noticed that the factory filter had more holes for oil flow.
ORIGINAL: amanda123
yeah even i get that whinning noise some times but if i leave it on idle for a few seconds it just goes away .. i really did'nt bother much ...... is it something serious.... ??
