Dodge Ram SRT-10 The best claim to fame. the world's fastest production pick up, the Dodge Ram SRT-10. With outstanding Viper inspired styling, power and handling, this sport pick up will blow the doors off anything that gets in it's way.
oil cooling lines
Old Mar 7, 2010 | 11:13 AM
Midnight Runner's Avatar
Midnight Runner
I thought it was just me to. The black srt10 leaks oil, i also changed the oil lines and still
leaks. The white C.E. dosen't leak. I'm going to look into buying those oil lines also.
Old Mar 9, 2010 | 06:47 PM
aceace0582's Avatar
aceace0582
Hey guys, got my oil lines today. The ones w/out the life-time warranty are $110 bucks but I paid $190 for the lifetime warranty ones. They look like they can take the pressure with no problems. Damn nice! Thanks again Ohio. Hey Ohio, should I have the dealer install them or can my regular mechanic do it? Also what type of oil filter do you recommend? Last but not least, I just started having a problem with fuel filling. It seems like the fill tube won't drain quick enough into the tank, so the pump keeps stopping and it takes forever to fuel. Any help would be appreciated. Thanks!
Old Mar 12, 2010 | 06:49 PM
CarGuyOhio's Avatar
CarGuyOhio
A back yard mechanic could do the swap. But go with who you feel comfortable.
As for the gas issue.... Does it happen at all stations? If so there is a possible vent issue.
Old Mar 16, 2010 | 05:50 PM
aceace0582's Avatar
aceace0582
Thanks Ohio! Yes the problem with fueling happens at all stations. I actually put a shop-vac vacuum hose tube in to the fuel fill tube just to see if anything would come out and nothing did.
Old Mar 17, 2010 | 07:39 PM
aceace0582's Avatar
aceace0582
Hey Ohio, how goes it? I had my SRT 10 on the rack today and unhooked the vent tube line from the fuel inlet spout. We blew compressed air through it but it did not fix the problem. I'm going to completely remove it from the tank and try to clear it. I'm pretty sure the vent valve on top of the tank flows only one way and is probably clogged for some reason.
Old Jun 15, 2010 | 06:32 PM
aceace0582's Avatar
aceace0582
Just an update on my fueling problem guys. It seems to have just gone away. My guess now is that it was some type of vapor/lock that happened in the venting system.
