I'ts been awhile since I've been on here and have a question .I need to replace the rear U joint, any special instructions or shortcuts I should know about?
I know i need to mark the drive shaft,but the kit comes with 4 c -clips and i only saw 2 and the 2 half moon clamps ,when i craweled under to check it out
You need all four. Two go on the cups that get pressed into the drive shaft and two go on the cups that fit into the differential yoke. Without them the drive shaft will not be centered and balanced.
