Distance between front seats...B250
Old May 10, 2007 | 04:32 PM
dropoutdave's Avatar
dropoutdave
Default Distance between front seats...B250
Hey all,
Am currently sat on a ship and wanting to order a new fridge to sit between the front seats on my 94 B250 before I get home, would anyone here know the distance between them? May aswell go for the biggest one that will fit in there to keep the beers cold eh!
Thanks
Dave
Old May 16, 2007 | 04:43 AM
IGadget's Avatar
IGadget
Default RE: Distance between front seats...B250
I see that no one seems to know the answer to the question, unfortunately my B250 is an 87, if you think that would matter enough I can measure it and give you a ball park figure. Thank you for your service.
-- IG.
Old May 16, 2007 | 03:01 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
I had the same thought to go and measure mine, but mine being a 2000 1500 I couldn't guaranty the measurement. Maybe if your 87 B250 and my 2000 1500 are the same, then that might be enough of a confirmation for dropoutdave to work with.
Mine is 21" between the seats, but only 18" between the seatbelt latches. Subtract a couple of inches on each side for finger clearance around the latches and you're probably left with about 14" comfortably.
Old Jun 8, 2007 | 07:07 AM
IGadget's Avatar
IGadget
I did do this last weekend before I scrapped the van, but didn't have time to post it since then. I marked 18.5 inches between the seatbelt buckles and 21" between the bases. I may have squeezed the buckles back to the seats more because one was bent out of shape from the monitor storage which the van was doing duty as. I didn't do a front to back meeasurement, because I had no rear seats in a cargo van. just make sure whatever you get it easy to pull back incase the doghouse has to come off for changing plugs,wires, filters and miscelany.
Good luck
