89' B250 5.2L surges at idle
Old Jun 13, 2007 | 05:26 AM
LiveFromHeaven's Avatar
LiveFromHeaven
Default 89' B250 5.2L surges at idle
Just got back from a trip up north and the van has started surging when parked. It's a sort of rythmic, pulsating surge that just started after a 250 mile drive. She runs fine otherwise, any ideas?
Old Jun 13, 2007 | 12:54 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Default RE: 88' B250 5.2L surges at idle
It's probably a dirty IAC. Here is the cleaning instructions.
https://dodgeforum.com/m_525409/tm.htm
Old Jun 14, 2007 | 09:18 PM
LiveFromHeaven
I'm looking through my chilton and it says the IAC was used in 92' and later models. Apparently my TBI uses a ISC (Idle Speed Control Acuator.) which connects to my thottle body. Should I remove this and clean with carb cleaner in a similar way the other proceedure?
Old Jun 14, 2007 | 09:28 PM
LiveFromHeaven
Or should i just try and replace with a new unit from NAPA?
Old Jun 14, 2007 | 11:57 PM
LiveFromHeaven
Well I broke down and bought a new ISC motor and now I'm stuck at the point of adjusting it. The Chilton says to disconnect the ECT wire before calibrating the idle screw, but I can't find the wire for the life of me. Says its on the intake manifold between the alternator and the AC compressor but I just don't see it. Is there another proceedure for adjusting the idle screw? I'll search the forum for awhile...
Old Jun 15, 2007 | 12:35 PM
alloro's Avatar
alloro
I don't think an ISC motor is going to solve the surging problem. They don't adjust fast enough to cause surging. I didn't notice the "89/88" in the subject line until just now, so sorry about throwing you in the wrong direction with my first post.
The first thing to check when there is surging on carbureted engines is the float level. Too high or too low and it will surge and nothing else you do will make it stop. So the float level is the very first thing you need to check.
Old Jun 15, 2007 | 08:53 PM
LiveFromHeaven
I'm not sure my TBI has a float, does it? I could very well be wrong. I beleive I finally found the ECT sensor, but my manual lists it as Coolant Temperature Sender. Is this the same thing? It's on the opposite side of the alternator/AC compressor closer to the pedals. Thanks again!
Michael
Old Jun 15, 2007 | 09:07 PM
LiveFromHeaven
The only wire I found running between the alt and the ac compressor was a single wire, right angle plug. Did they ever design these without a ground wire or something?
