1997 ram 2500 v6
Old Jul 3, 2007 | 03:24 PM
alphha's Avatar
alphha
Default 1997 ram 2500 v6
The check engine light continues to blink. The van will bog down under acceleration and sometimes backfire a little bit.
Old Jul 3, 2007 | 05:58 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Default RE: 1997 ram 2500 v6
A blinking engine light is a warning of a majorly rich exhaust. This is a warning that the engine should not be run until the problem is fixed because it will cause the catalytic converter to fail within minutes.
Old Jul 4, 2007 | 02:56 AM
alphha's Avatar
alphha
Update I am gettting trouble codes 42 and 43?
Old Jul 4, 2007 | 01:08 PM
alloro's Avatar
alloro
Although there are multiple possibilities for these two codes I believe these will end up being the pertinent ones.
42 Fuel pump relay control circuit
43 Cylinder misfire
Old Jul 5, 2007 | 01:17 PM
alphha's Avatar
alphha
What could be some of the probable causes for this?
Old Jul 5, 2007 | 04:49 PM
alloro's Avatar
alloro
Most likely your fuel pump circuit is shorting out intermittently, possibly due to the fuel pump motor starting to go bad. The cylinder misfire could be a direct result of a non-steady fuel supply. I think if you get the code 42 fixed first, then the code 43 will take care of itself.
Old Jul 5, 2007 | 07:28 PM
alphha's Avatar
alphha
Code 42 was fixed when i replaced Auto shutdown relay.
I only get 43 now. I am going to try changing the plugs and a new distributer cap and roter.
It runs and the check engine light only flashes after I have to accelerate hard. Then it misses and runs rough for a bit until the check engine light quits binking. then it occassionaly has a slight miss.
Old Jul 5, 2007 | 07:42 PM
stev's Avatar
stev
ORIGINAL: alphha
When you go for the new cap-n-rotor, don't be cheap. Those cheap parts have aluminum contacts. Instead ask for the better cap-n-rotor parts that are copper/brass contacts. This will save you headaches down the road too.
The Wells brand has a good copper/brass cap-n-rotor set that has worked well on my Ram Van/Wagon. They were only $3 more than the cheap aluminum types at AutoZone.
Peace!
Stev
