Oil Question 20w50 or 30w
Old Jul 16, 2007 | 10:57 PM
kaizen1's Avatar
kaizen1
Default Oil Question 20w50 or 30w
Hi,
I have a 1988 dodge 1 ton ram van on propane.
she burns quite a bit of oil and i use it everynight for about 2 hours for a courier run carrying newspapers.
I have been told to use and have been using 20w50. would putting heavier oil in it reduce the oil consumption???
Old Jul 17, 2007 | 02:37 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Default RE: Oil Question 20w50 or 30w
Slightly but not much. Once 20W-50 is heated up, it flows about as fluidly as 10W-30.
Old Jul 17, 2007 | 02:42 AM
Captain Squalus's Avatar
Captain Squalus
ORIGINAL: alloro
the above is not correct
20w-50 flows as 50w hot and 20w cold
10w-30 flows as 30w hot and 10w cold
Old Jul 17, 2007 | 12:18 PM
alloro's Avatar
alloro
Maybe new in the bottle at room temperature. But in the real non-laboratory world, onceboth areheated up to engine temperature, you will not be able to tell the difference between the two. I've used both, and yes 20W-50 pours in slower than 10W-30 but it drains out just as fast.
Old Jul 17, 2007 | 02:02 PM
Captain Squalus
ORIGINAL: alloro
Did you use a viscosity cup To measure it?
If you didn't your observation is worthless.
Old Jul 17, 2007 | 02:34 PM
alloro's Avatar
alloro
If it's viscosityneeds to be measured to tell any difference, then that only goes to back up my remark of there not being much of a difference between the two.
Old Jul 17, 2007 | 03:39 PM
Captain Squalus
ORIGINAL: alloro
There is not much differance between .005 and .010 clearance either but one the motor stays together the other it comes apart.
You obvousely don't have a clue as to how oils are rated.
So quit trying to give bad advise on a subject you know nothing about.
Old Jul 17, 2007 | 09:45 PM
alloro's Avatar
alloro
After 30 years of vehicle repair, renovations, repair manualsand text books, I know very well how and why oils are rated the way they are. I also know what is what in the real world. A motor that burns "quite a bit" of oil a day is not going to see any benefit if the oil is switched over to 30W from 20W-50 like the original poster asked. That's all he wanted to know and all you've gone and done is confuse the issue with your rhetoric.
Old Jul 18, 2007 | 02:43 AM
Captain Squalus
ORIGINAL: alloro
The only thing you said that was correct is"slightly but not much" the rest was worthless.
PS I was building a racing Offys before you were born.
Old Oct 13, 2007 | 04:49 PM
Suprageezer's Avatar
Suprageezer
Take a read at this website and do some self education on oil viscosity. Thick oil is bad, I run 5-30 Castrol and would run German Castrol 0-30 if I could get my hands on it.
http://63.240.161.99/motoroil/
