RAM 2500 VAN HEATER CHANGES TO
Old Jan 7, 2004 | 07:04 PM
m38mpp's Avatar
m38mpp
Default RAM 2500 VAN HEATER CHANGES TO
<FONT face="Times New Roman, Times, serif">I HAVE A 2000 RAM VAN 2500 I HAD THE HEATER RESISTOR FIXED AND A VACCUM POT REPLACED (A ROUND THING WITH A VAC LINE INTO IT) BUT STILL HAVE A PROBLEM. WHEN I ACCELERATE WITH THE HEAT ON THE HEAT CHANGES TO DEFROST THEN WHEN I LET OFF IT CHAGES BACK TO HEAT.THE 5 STAR DODGE DEALER HAS HAD THE VAN IN 3 TIMES FOR THIS NO FIX YET...ANY TAKERS..THANK MIKE POLETTI</FONT> <edited><editID>m38mpp</editID><editDate>37993.6712037037</editDate></edited>
Old Jan 27, 2004 | 01:06 AM
jkloet's Avatar
jkloet
Hello are you having problems with the windows fog up?</P>
</P>
Old Jan 27, 2004 | 01:14 AM
m38mpp's Avatar
m38mpp
NO THE WINDOWS DO'T FOG BUT LIKE I SAID THE AIR SWITCHES FROM COMING OUT THE FLOOR TO THE DEFROSTER AND WHEN I LET OFF THE GAS IT GOES BACK TO NORMAL
Old Jan 27, 2004 | 09:02 PM
Booda's Avatar
Booda
Sounds similar to a prob I had on an old Ford.</P>
Here we go...</P>
Most climate control systems are vacuum operated. The system gets its vacuum from the engine.</P>
What happens is when you step on the gas, the engine creates more vacuum. </P>
Sooo.. its possible that with more vacuum it will collapse a vacuum hose to your climate control, (they are about 3/16 in diameter).</P>
What causes it to open and close under acceleration is the air diffuser inside your plenum is spring loaded with a vacuum diaphram. If the vacuum hose is collapsed, the diaphram is released and the spring pulls the diffuser to defrost.</P>
I hope this helps. Dont know if it applies in your case but should give you some insight.</P>
If I am wrong I hope someone will correct me.</P>
</P>
Jeff</P>
Old Jan 27, 2004 | 11:25 PM
71_deputy's Avatar
71_deputy
m38- does it have air conditioning????
Old Jan 27, 2004 | 11:38 PM
71_deputy's Avatar
71_deputy
looking at the manual- check for 8" of vac, check the vac check valve- if it cann't keep the vac on the one setting- the low rpm's may cause the actator to change due to low vac source.</P>
check for a cracked, broken or loose vac on engine, check valve, reservoir and control unit.</P>
</P>
john</P>
Old Jan 27, 2004 | 11:44 PM
m38mpp's Avatar
m38mpp
BROUGHT IT BACK TODAY AND THEY FINALLY FIXED IT TOOK THEM TWO HOURS TO FIND IT.IT WAS AS YOU SAY A CHECK VALVE NOT HOLDING THE VAC UPON ACCELERATION. THANK YOU FOR YOUR HELP I GAVE THE DEALER A HEADS UP ABOUT THIS FORUM AND THATS PROBABLY WHAT HELPED HIM FIND IT. THANK YOU,MIKE P</P>
Old Jan 28, 2004 | 12:25 PM
71_deputy's Avatar
71_deputy
10-4 HAPPY HEATING!!!!!!
