Leak Detection Pump? 1495
Old Nov 13, 2008 | 11:34 AM
  #21
spyder98's Avatar
spyder98
that explains it, but know the D is reving wierd at idle the RPM goes up and down, but it doesnt stall
Old Nov 14, 2008 | 12:05 AM
  #22
Mobile Auto Repair's Avatar
Mobile Auto Repair
Clean the IAC motor. Here is a link from Stev about how to clean it. In most cases that will solve the problem of irradic idleing.
https://dodgeforum.com/forum/dodge-ram-van/68174-diy-how-to-clean-the-iac.html
You will need Q-Tips, Carb cleaner, paper towls, flash light, and a Torq bit screwdriver.
Took me about 30 minutes to do from start to finish including removing and reinstalling the "dog house".
Old Sep 13, 2013 | 02:27 PM
  #23
jmbkdrmn's Avatar
jmbkdrmn
Default Po441
what most likely causes this code, I smell fuel out side the cab.
Old Sep 13, 2013 | 11:04 PM
  #24
alloro's Avatar
alloro
Van & CUV Section Moderator
The easiest solution is the gas cap isn't sealing.
Old Apr 8, 2017 | 03:44 AM
  #25
Geoff Gihle's Avatar
Geoff Gihle
Default P1495
Where is the LDP located? 2000 dodge ram van 1500.
