EGR time delay switch
Old Aug 9, 2007 | 08:30 AM
Tom Norman's Avatar
Tom Norman
Default EGR time delay switch
I've got a 1988 B350 Ram van with the 360 engine. The voltage regulator went south recently, and the uncontrolled voltage fried my battery isolator and it looks like it also fried the EGR time delay switch. Damage to the battery isolator was obvious; one of the isolator posts overheated,melted the epoxy resin, eventuallycausing an internalshort and major arc.
I examined other components on the firewall and it looks like the EGR time delay switch was also damaged. Not as bad as the battery isolator, however, it was obvious that the epoxy resin containing the internal components had become very hot. Some of the epoxy resin had melted and I could seedroplets of melted epoxy resin on the firewall underneath the EGR time delay switch.
I plan on replacing the EGR time delay switch, butwhat are signs that the switch is, in fact, toast?I've noticed that the van is a bit harder to start in the morning, and it's also harder to start when hot. When hot, it takes a lot of cranking to get it to start. Once started, it runs smooth as silk. It just takes a lot of cranking do get it to fire. Are these symptoms of a bad EGR time delay switch?
Old Aug 10, 2007 | 03:24 AM
Tom Norman's Avatar
Tom Norman
Default RE: EGR time delay switch
Nobody?
Old Aug 12, 2007 | 08:52 PM
Tom Norman's Avatar
Tom Norman
The dodge talk dot com forum provided the solution to my hard-starting issues:
The uncontrolled voltage killed the ignition module too. Upon closer examination, the ignition module has tiny trails of melted epoxy resin that leaked out from inside the module. I'll be replacing the ignition module AND the EGR time delay switch.
Hopefully, nothing else was damaged!!!
