96 Ram 1500 Cargo 3 speed Trans fluid
Old Nov 25, 2007 | 09:36 PM
tubejoe's Avatar
tubejoe
Default 96 Ram 1500 Cargo 3 speed Trans fluid
New to the forum. Is dextron OK for this model year with 3 speed trans?
Joe
Old Nov 25, 2007 | 09:42 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Default RE: 96 Ram Cargo 3 speed Trans fluid
Manual tranny - Dextron II or Mercon auto tranny fluid. (Yes, auto tranny fluid in a manual tranny.)
Auto Tranny - ATF +3 or Type 7176 auto tranny fluid.
Old Nov 25, 2007 | 10:20 PM
tubejoe's Avatar
tubejoe
Thanks for the quick reply. Will my local auto parts store have 7176?
Old Nov 25, 2007 | 10:30 PM
alloro's Avatar
alloro
Some do some don't, some carry it but are out of it frequently. The only way to know for sure is to call them or just stop by.
Old Nov 26, 2007 | 10:41 AM
tubejoe's Avatar
tubejoe
No luck with 7176 at the local dealer or parts store. Likewise with +3. Dealer/parts store,says +4 will work. Is that ture?
Old Nov 26, 2007 | 10:48 AM
alloro's Avatar
alloro
Yes, +4 supersedes +3.
Old Nov 26, 2007 | 05:34 PM
tubejoe's Avatar
tubejoe
Thanks. Fluid changed to ATF +4 synthetic. 160,000 and shifting smooth.
Regards,
Joe
Old Nov 29, 2007 | 05:46 PM
stev's Avatar
stev
http://www.pennzoil.com/products/tra...atf_plus3.html
"...Pennzoil® ATF+3 is an automatic transmission fluid designed specifically for automatic transmissions and transaxles used in Chrysler vehicles. It is fully compatible with Pennzoil® 7176 ATF. It is manufactured with specially selected friction modifiers, highly refined base oils and a shear stable viscosity index improver. ATF+3 ATF has excellent oxidation and thermal stability for long mileage component protection...."
I've been told in the past that the Dextron III is not the same as ATF+3 for Chrysler vehicles and to avoid using it at all costs. IF you read the Dextron III claims, it says recommended, but not aprroved per Chrysler specifications.
Even Castrol who is in the automotive oil business spells out that Dexron III and AFT+3 are different critters.
Castrol is "Certified" ATF+3 and ATF+4 for chrysler vehicles.
http://www.castrol.com/castrol/secti...tentId=7027046
