No Oil Pressure- Need a new Engine?
#41
RE: No Oil Pressure- Need a new Engine?
A vacuum reading of 17 at idle is on the low side to begin with. A normal reading is up around 20. So you likely have either a vacuum leak or the bad valve is slightly open even at idle. If you have the time, it wouldn't hurt to do a compression test while you're driveway bound, just to rule out some possibilities.
