Engine Compatibility
Old Feb 12, 2008 | 12:38 PM
markoman's Avatar
markoman
Default Engine Compatibility
I amlooking to buy a rebuilt 318long blockto replace the engine inmy 1988 B250 Dodge Van.
The engine I am considering displays an engine number of 2B416994 stamped on the lower Right side of the block just above the oil pan mounting. Thisis consistent with the display indicated for 1985-88 V6 & V8 engines in Figure 7 on page 1-18 ofmy Chiltonrepair manual for 1967-88 Full-size Vans.
Here is the issue I am confronted with: I amtold the engine I have looked at is a 1968-74 model. However, thatis inconsistent with the Chilton's manual--which displays and states in Figure 6 on page 1-17 that engine numbers for 1967-84 V8's are located on the Left front of the block below the cylinder head This engine does not have a number in that location.
Cananyone advise whether this engine is the 1985-88 series 318 asthe Chilton'smanual suggests?
I have not measured dimensions, location of motor mounts or head design--but it all looks very similar to the stripped down block in my van.
If not; where can I find out what year it was produced and whetherit is compatible with this installation?
I appreciate any help of leads anyone can provide. I have not had any success talking with places like dealers or repair shops on this topic.
Old Feb 12, 2008 | 02:47 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
Default RE: Engine Compatibility
One of, if not the best history write-ups I've seen on the 318 is on this page about half way down.
http://www.allpar.com/mopar/318.html
A couple of sections past the 318 section look (or search) for "Identifying LA Series V-8 engines and parts interchange". Although engine numbers are not listed, there is a pretty good description of the differences between the different versions. There might be enough there to give you some clues.
Old Feb 13, 2008 | 01:41 AM
markoman's Avatar
markoman
Cool--I'll look it over. Thanks much!
