'79 5.9L Header & Dual Exhaust?
Old Mar 26, 2008 | 12:56 PM
chazman0462's Avatar
chazman0462
Default '79 5.9L Header & Dual Exhaust?
I bought thisfrom a coworker to use it for occasionaltowing(2500~3000 lbs). Would installing a header (Dynomax for only $250) help towing performance? Many years ago I installed a header onmy 4-cyl Celica andlost lots of bottom endtorque.Iwant to increase low to mid range torque on my van - say about 1500 to 3000 RPM where I use the most. Also, I'mthinking about dual exhaustbutnot sure how itwould affect thetorque curve. Any advice?
[IMG]local://upfiles/86507/F8F3CE546F23446EACDD6ADB57420912.jpg[/IMG]
Old Mar 27, 2008 | 10:34 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Default RE: '79 5.9L Header & Dual Exhaust?
Headers or dual exhaust will not help you in the low to mid range. Both are beneficial in the upper RPM range because that's when you have a higher volume of exhaust gases and the potential for excessiveback pressure.
The cheapest way for you to increase bottom end power is to install a new timing chain set that has the extra keyways for adjusting the valve timing. Installing it so that you get 3-4 degrees of valve timing advance will shift your power range towards the lower RPM range. This will of course reduce your upper RPM power.
