93 B150 Climate Controls
Old Apr 8, 2008 | 03:27 PM
Rusty93RamVan's Avatar
Rusty93RamVan
Default 93 B150 Climate Controls
This week my A/C stopped working.
The heater works fine - it iswarm and blowing properly through the foot vents. But when I switch to A/C I don't get any cold air through the front dash vents even though the fan still runs.
The Defroster still works OK. In Defrost mode, I get air through the top defroster vents and the compressor does turn on.
But I get no A/C (Push) or Vent (Pull) through the front dash. Bi-Level A/C (Push/Pull) is also not working. Any idea what's wrong?
Old Apr 9, 2008 | 04:34 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Default RE: 93 B150 Climate Controls
I'd say either your selector switch is bad or the vacuum actuator for the dash vents door sprung a leak. No fun getting to that, it's really buried up in and around the heater box.
Old Apr 11, 2008 | 07:38 AM
Rusty93RamVan
I was thinking it might be a vacuum problem. I'm getting a pretty good amount of air thru the defroster vents in A/C mode so I guess I'll just leave it unless I feelsuddenly inspired one day to disassemble the dash. Wouldn't bet on that.
Old Apr 16, 2008 | 06:45 PM
Rusty93RamVan
Well, I got lucky. The main vacuum line (black tube) running from the engine compartment to the selector switch was compromised. A hose clamp near the A/C boxon the front right side of the engine bay wore a hole in side of the plastic line. I just cut out the bad piece and put a 1/4" vacuumhose in place to repair it. My selector switch now working perfectly again.
Old Apr 17, 2008 | 03:36 AM
alloro's Avatar
alloro
That's odd, usually when the main line is effected you will only get defrosters and no floor or dash vents. I guess you were getting just enough vacuum to open the floor vent, but not quite enough to open the dash vents. I'm glad someone got lucky for a change.
Old Apr 17, 2008 | 10:41 AM
Rusty93RamVan
With the open line I was getting about 85% defroster and 15% floor, so you are correct. I was definitely due some luck with this van. With 260K miles you have to expect maintenance, but I've been fixing almost as much as driving lately.
