Changing the bulb on the Check Engine Light
Old Jun 1, 2008 | 08:54 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
Default Changing the bulb on the Check Engine Light
Has anyone ever changed the bulb on th "Check Engine" lamp? What is involved in changing one?The oneon my 97 Ram B2500 does not work.
Old Jun 2, 2008 | 09:24 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Default RE: Changing the bulb on the Check Engine Light
You have to pull out the instrument cluster to change it. Once the cluster is out give the socket a 1/4 turn to the left and pull it out. The bulb can then be pulled out of the socket.
Old Jun 9, 2008 | 07:09 PM
IGadget's Avatar
IGadget
If you are limber and have skinny arms you can sometimes grab them from below too. Then you have to do everything by feel.
Old Jun 9, 2008 | 07:35 PM
Mobile Auto Repair
ORIGINAL: IGadget
I tried that and was not able to.
Any tricks on removing the cluster? I have not tried yet and don't want to goof it up.
Old Jun 9, 2008 | 11:20 PM
alloro's Avatar
alloro
ORIGINAL: Mobile Auto Repair
We could tell you, but then there would be no fun in it for the rest of us.
Old Aug 6, 2016 | 11:56 AM
Charlie McCollum's Avatar
Charlie McCollum
Default Charlie McCollum
I have the same problem. Is it necessaary to remove the kick plate from below the steering wheel or can I remove the cluster bezel easily with a thin tool to release the clips? I would appreciate any advice. Need a new Check engine bulb
Thanks
