hi from italy
Old Jun 20, 2008 | 08:57 PM
italian dodger's Avatar
italian dodger
Default RE: hi from italy
in italian "alloro" is atree that i use for cooking spaghetti!!!!!! i don't know its name in english!!!!
good night!!!!
i go to sleep (in italy are 3AM!!!!!!!!!!!!!)
Old Jun 20, 2008 | 09:28 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
You cook spagetti in a tree? [sm=laughat.gif]
Old Jun 20, 2008 | 09:34 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair
I believe he was tired when he posted that one, hehe. I prefer to cook mine ina pot.
Old Jul 1, 2008 | 06:07 PM
italian dodger
I wrote this????eheh i said you that mine is a very bad english!!!!! i cook spaghetti in a pot.....
well.... my vancarried me at home..... but with some new problem........
UFFA!!!!!!!!!!!!!!!!!!!!!
when i'm decreasing speed at 35 m/h the gear pass to neutral!!!!!!!!!!!!!!!!!! (why????) bah!!! i hope to find a good mechanic for this type of car....
inbologna, at 2pm with 42 °C and stopped in highway for 45 minutes the clima died.... lucky trip eheheh
mah!i go to sleep!!!! tomorrow is a heavy day at work!!!!!!!!!
bye
Gian
Old Jul 1, 2008 | 06:20 PM
alloro's Avatar
alloro
ORIGINAL: italian dodger
You might have a broken motor or transmission mount. If one of those is broken the motor and tranny could be moving around and forcing the shift linkage to slip the tranny into neutral.
Old Jul 1, 2008 | 06:51 PM
Mobile Auto Repair
I hope it is the motor and/or tranny mount. I have(mine is only when below freezing tempatures) a simular problem with the transmission in my old Impala and it turns out to be a internal problem. The only way to fix this if it is not a broken motor/tranny mount and the gear selector is not being moved into neutral (where you have to pullthe selector handleback into the "D" position) is to have the tranny rebuilt. If you are having to move the gear selector back to "D" position when it happens then as Alloro said youshouldfind abroken mount.
Old Jul 1, 2008 | 06:53 PM
italian dodger
ORIGINAL: alloro
what's motor? what's "transmission mount"? tranny ???????
i'm a very silly boy... (or stupid is better...)
thanks!!!!!!!!!!
good night
now is really time to go to sleep....
Old Jul 1, 2008 | 06:57 PM
Mobile Auto Repair
Motor = your engine
Tranny = your transmission
The mounts are what hold the engine and tranny to the van's frame. With out them the engine and tranny would fall out of the van.
Your engine has 2 motor mounts (side of the motor towards the middle and bottom of the block) and the tranny has one usually towards the back of the tranny just before the drive shaft.
Old Jul 1, 2008 | 07:02 PM
Mobile Auto Repair
I am sure you are not silly nor stupid. Your english is way better than my Italian, for I do not know Italian at all. I wish I did know some of the Italian automotive terms where I could help you understand your van better. Anyway I am glad to help the best way I can.
Old Jul 1, 2008 | 07:36 PM
alloro's Avatar
alloro
Ask and you shall receive!
From: http://www.international-auto.com/in...cid/15/sc/8140
ITALIANO ENGLISH
accelerazione Acceleration
accensione Ignition system
albero a camme Camshaft
albero a gomiti Crankshaft
alesaggio Bore
altezza Height
altezza minima da terra Ground clearance
ammortizzazione Shock absorbers
asse posteriore Rear axle
aste Pushrod
barra Panhard Panhard rod
benzina Gasoline
berlina Sedan
berlinetta; coupe Coupe
bilanciere Rocker arm
bobina Coil
braccio triangolare Control arm (a-arm)
cabriolet Convertible
cambio automatico Automatic transmissione
cambio di velocita; scatola del cambio Gearbox
cambio planetario Planetary gear
candele Spark plugs
carburatore Carburator
carburatore a doppio corpo Two-barrel carburator
carburatore a quadrupio Four-barrel carburator
carreggiata Track
carrozzeria Bodywork
catena Chain
cavi delle candele Spark plug wires
chilometro Kilometer
cilindrata Displacement
cilindri Cylinders
cilindri a v V engine
cilindri contraposti Horizontally-opposed engine
cilindri in linea In-line engine
cinghia della ventola Fan belt
consumo di carburante Fuel consumption
convertitore di coppia Torque converter
coppia Torque
corsa Stroke
cuscinetto di biella Rod bearings
denti Teeth (of a gear)
destro Right
diametro di sterzata Turning circle
differenziale scorrimento limitato Limited-slip differential
dinamo Generator
disco frizione Clutch disc (plate)
faro Headlight
fasce elastiche Piston rings
filtro aria Air cleaner
filtro dell'olio Oil filter
finestra Window
freno Brake
freno a disco Disc brake
freno a mano Hand brake
freno a tamburo Drum brake
frizione Clutch
ghisa Cast iron
grasso Grease
guarnizione della testata Cylinder head gasket
ingranaggi Gears
iniezione Injection
larghezza Width
lavacristallo Windshield washer
lega leggera Light alloy
leva di commando Gearshift lever
lubrificazione Lubrification
luce dello stop Brakelight
luci di coda Tail lights
lunghezza Length
lunotto posteriore Rear window
macchina Car
manutenzione Maintenance
marcia Gear ratio
mensolina centrale Console
molla a balestra semiellittica Semi-elliptic spring
molla a barra di torsione Torsion bar
molla delle valvole Valve spring
molla elicoidale Coil spring
motorino d'avviamento; starter Starter motor
numero di ottano Octane number
olio Oil
parabrezza Windshield
passo Wheelbase
pastiglie Linings (brake)
peso Weight
pistone Piston
pneumatici Tires
pneumatici radiali Radial tires
pompa d'alimentazione Fuel pump
pompa della benzina Fuel pump
pompa di ripreso Accelerator pump
porta Door
posto Seat
potenza Power
punterie Tappet
puntine Breaker points
quadro di bordo Instrument panel
radiatore Radiator
rapporto di compressione Compression ratio
ruote Wheels
ruote anteriore Front wheel
ruote posteriore Rear wheel
scatola sterzo Steering gearbox
servosterzo Power steering
sincronizzato Synchronized
sinistro Left
sormoltiplicatore Overdrive
sospensione Suspension
sospensione a route indipendenti Independent suspension
sospensione anteriore Front suspension
sospensione posteriore Rear suspension
spider Roadster
stabilizzatore transversale Anti-roll bar (sway bar)
sterzo Steering
sterzo a cremagliera Rack & pinion steering
supporti dell'albero motore Main bearings
telaio Chassis
tergicristallo Windshield wiper
termostato Thermostat
testa cilindri Cylinder head
tirante elastico McPherson strut
trasmissione Transmission
trasmissione anteriore Front wheel drive
trasmissione posteriore Rear wheel drive
valvola Valve
valvole in testa OHV
velocita Speed
velocita massima Maximum speed
ventola Fan
